Re: TT - best & worst model/year? (sharons03jetta)
I work on VAG cars daily,and to be honest my 00'TT is more reliable than most of the VW's that come in.
I think a lot has to do with previous owners when it comes to how well a TT is mechanically.
The 225 is more complex and is costlier when it comes to parts and repair due the the more complex turbo system as well as the Haldex system,and added complexity/more parts with the quattro drivetrain.
You have 2X as many driveshafts and CV boots to wear out,and transmission is more difficult (read expensive)to remove for clutch work,and you have driveshaft,rear diff,and many bushings on the rear multi-link suspension to wear out.
If you are the owner pre-100K,then you will enjoy a excellent car,and only usually after 100K do the things I mentioned above become a issue.These are very well built, and tough cars,and see no reason why they won't do 200K on same engine and trans if properly maintained.
The above reasons (and the fact I do not have many twisty roads/no snow in my area)are why I picked a 180hp FWD,also because I plan to keep it past 100K(58K now) and if I ever blew a tranny or motor,a unit from some model Golfs/Jettas will bolt right in.Basically I went for simplicity,the the less complex,the fewer things that can break,and these cars are (relatively) cheap to keep on the road.'
A lot also depends on where you live,and what type of service facilities are available........if you live far away from a good Audi shop,then get the 180HP FWD basically a VW.
If you have a good service shop and don't mind the added expense,and complexity,get a 180TTQ,or 225TTQ.
As for years,the later ones seem to have fewr elctrical isses,and better vacuum hoses.Gauge clusters also have less failures.
Good luck.....all TT's rock!
