Re: TT exhuast clerance problems (Fast16v)
The second resoantor reduces cabin groaning, but the inside of it is the same size as the rest of the exhaust piping, so the out the tail pipe sound is not effected. Very worth it in a VR6. As to the fit, I have found that the TT to cat clamp they give you is not enough as the connection tends to droop pulling the entir system of of alignment. You should stick a 2x6 or a little more under the brace (the one under the cat) which will hold the system up. Then make sure it is slid foward all the way onto the Cat, and then have 2 or 3 small tack welds put on it....the alignment will be perfect. This needs to be done on an alignment style rack by the way that allows you to lift the car with the wheels supported, not dangling like a regular lift....
Sean
