HI, I have had a few P04DB codes thrown on my 2012 TT-RS with UM Stage 2 tune. Note that I have the "v1" version of the tune (or at least the first version released to the general public). In the past, I would only get the code on cold days (<32deg) and with <1/3 tank of gas. I haven't been driving it often during the winter. I would see the code once or twice per winter and only during the winter. I have assumed it was an issue with the original Audi TT-RS OEM tune, used as the basis for the UM tune back in 2012-13.
This week the code popped up again. This time though it came back on within a day or so. It was in the mid-40's and I had just less than a full tank (about 3/4 full) when it through the code the second time. This makes me question the theory that the OEM Audi tune has a bug, causing the code to the thrown.
I know that the P04DB code points to the PCV system and that if there is an issue with the PCV system, Audi calls for replacing the entire valve/cam cover (list price $680, selling for ~$500).
Question: Before I spend $500 on a new cam cover, has anyone had problems with the P04DB code and had the issue fixed by a software/ECU update? Back in 2013, people with TT-RS's and stock ECU flashes were reporting this code, but I can't find any definitive answer whether Audi updating the ECU flash fixed their issue OR did Audi end up having to install new cam covers as well?
I was already planning to have UM update my ECU flash to the latest version. I will probably start with that and see if the code comes back. However, if I do have a problem with the PCV system, I want to address it sooner rather than later.
Thanks for the help.
