Well. What a week it's been. I've been driving the Dasher to and from work. It's been very... illuminating.
I already knew this, but I'm writing this here to remind myself every time I see this thread; Carburetors are a great way to deliver properly proportioned fuel. IF they're setup correctly.
This thread is going to be the story of my journey to that point. Maybe a weekend thing? Probably a 2-3 weekend thing?
The story so far: The 32/36 is a substantial joy enhancer on my 1.8.
Sunday: Great time driving the Dasher. The instructions for the choke setup are solid, and it warms up just as I would expect it to. Waking up slightly earlier to accommodate.
Monday: Idle and very low throttle is becoming a bit uncertain. Sometimes high, sometimes low. I assume the idle speed screw may be too far in, occasionally exposing the transition holes and causing rich conditions. I try and adjust accordingly after work.
Tuesday: Closing the idle speed screw did not have an effect on the wandering idle. At times when it is idling normally, I have adjusted the idle mixture screw and I don't suspect it. Occasionally I have to bump the throttle at idle because if I let it go it will die.
Wednesday: Okay, something is definitely wrong here, settings adjustments are not doing what they should, car isn't doing what it should, it's becoming a bit stressful. I scratch my head. I start making a list of things to rule out. I start this thread.
Thursday is my Friday. Here are the things I'm going to do this weekend to rule out various vectors of vehicular vroom-icide.
In addition to these easy tasks, I also have a jetpack coming in the mail soon. Possibly Friday.
I'll try to take pictures.
- Redline mentions that their manifolds are made for more than one application, and thus some clearancing may need to be done to clear the exhaust. I did this with a hand file, and I was pretty sure it was good but ultimately I am not satisfied with the finish or the amount of material I was able to remove. I'm going to use a die grinder to ensure the fit is perfect.
- The phenolic spacer supplied with the kit is seriously not flat. I used it anyway, and I regret that. I'm going to do what I can to smooth the surfaces more. Depending on how well that goes I may add a gasket or sealant.
- I'm going to fiberglass wrap the exhaust manifold, and attempt to RE-install the plated heat shield which normally sits above the exhaust. I have not identified this as THE problem, just that most would say it's going to be a problem at some point.
- My base ignition timing is set for 6 BTDC, with centrifugal advance only, no vacuum (busted diaphragm). I'm considering advancing slightly in order to increase total advance with the centrifugal.
