Basic with out Lambda, it would not work, though on a pure basic setup, you could manipulate the heating strip in the WUR.
From what I gather in this someone is writing about sending a signal to manipulate the frequency valve duty cycle (lambda valve), in order to regulate upper to lower fuel cahmber pressure. In theory it will work, applicationally, it will take a lot of trial and error, especially if you are dealing with a boosted application.
I know because I am, although I am doing it to a CIS-E platform (K-Jetronic), with the DPR, taking the Lambda's place and enhancing it with faster and finer response.
Though applicationally, my setup is a crude hodgepodge of a Hobb switch and playing with a fixed signal to effect the DPR (future plans are a MAP and TPS). All this while using my wideband as a "window" into the running conditions so I don't melt pistons.
