Re: Tuning self-adjusting cam gear with TT266 cam (Fast2.0L)
This is a great idea. Now, I do have three questions relating to it.
1. Since this self-adjusting Cam Gear is a mechanical device, how long would it be before the springs begin to wear down? So I guess my question is,
how long of a life span will this product have?
2. From what I saw, there were no power increases in the 6000 RPM range, even using a high deg. cam like a 276. Would this be due to the testing been done on older, un-tuned (chip wise) engines? or would it be due to the timing?
3. Would a performance ECU have any possitive or negative effect when using this Cam Gear?
8v-inside: since you've been talking to the company, you should have them use you as a test/marketing mule and get some before/after dyno runs using their Cam Gear. Maybe get the product and dyno runs for free
because I would love to see more info (before/after dynos) from newer engines.
