Turbo Inlet install from under the car?
748 Views 9 Replies 4 Participants Last post by  Bug_Power
How exactly would you install it from under the car? Do you just jack it up and the pipe is right there to unbolt?
Thanks
Patrick
1 - 10 of 10 Posts
Re: Turbo Inlet install from under the car? (One Dub Nut)
I'm curious about this also, who has installed these by themselves? Which brand did you use, and how difficult was the install? I feel I'm pretty handy, but really would prefer to not mess up my turbocharger. Anyway, any experiences would be welcome.
Re: Turbo Inlet install from under the car? (MikeyG_U2)
TTT
You're going to work from over and under to do it quick. From the top; take the airbox out, to disconnect inlet hose, pull out clip. From the bottom; remove coolant hose hex screw from block, remove inlet pipe hex screw, remove inlet pipe. Assemble in reverse order.
Re: Turbo Inlet install from under the car? (9VW23yrs)
Someone needs to post some pics if they can because this is somewhat complicated.
Patrick http://****************.com/smile/emthup.gif
See less See more
See less See more
Bump
I didn't do anything about coolant hoses. You have to remove the airbox 2 bolts, Then remove/Unplug the Maf and rubber intake Boot. Just place it on top of the engine, there is a clip at the bottom of the rubber pipe that will have to come off to get the intake hose out of there. From there you can remove the hose that goes to the N75 valve from under the car. Now there is 1 Hex nut that holds the inlet pipe on. You'll typically need the rubber Oring that is in there for your new one. Just place it in the groove for the new one and assemble in the reverse order.
Re: Turbo Inlet install from under the car? (Bug_Power)
quote:[HR][/HR]rubber intake Boot. the hose that goes to the N75 valve [HR][/HR]​
I have no clue what these are. Could someone snap some pics for us idiots?
Thanks
Patrick
Thanks
Patrick[HR][/HR]​
Okay look at your intake it goes in this order. Airbox->MAF sensor->Rubber Intake Boot->turbo inlet pipe. Got it. It's what your Diverter Valve is plugged into. Also see the nipple on the new Intake pipe? That's where the N75 hose goes.
1 - 10 of 10 Posts
