1 - 9 of 9 Posts
I was told by a buddy of him with the Greddy Turbo Timer on his 2002 GTI, that the 2003 moel does have different wiring and it is possible to wire it up but still keep total use of the stock alarm. Is this possible?
Re: Turbo Timer and GTI 2003? (roly)
I guess Logan doesn't believe me does he....huh Roly
Logan we have been at this Turbo Timer thing alot longer than you have been here on the tex
here is some material for you to read http://forums.vwvortex.com/zerothread?id=581307&page=8
[Modified by quicksilver337, 10:47 AM 3-19-2003]
Re: Turbo Timer and GTI 2003? (quicksilver337)
Thanks quicksilver couldn't have said it better myself but we will have a solution this weekend Im going to meet christian in NJ
Re: Turbo Timer and GTI 2003? (VWJTI1.8T)
dude...im not doubting you...i just want a second opinion.... http://****************.com/smile/emthup.gif
Discussion Starter · #6 ·
Re: Turbo Timer and GTI 2003? (Spd)
luis...should i just follow the directions that the guy posted on page 8 (loooong post with detailed instructions and diagrams)?...just do those and the alarm will work PERFECTLY?!?!
Ok, I have a question, I don't know much about the whole turbo thing this is my first VW, and I don't know if anyone has posted this question before. But has anyone tried having it installed at a shop to see if they have a solution for this problem. If so what have they told you.
Re: Turbo Timer and GTI 2003? (neu318)
quote:[HR][/HR]Ok, I have a question, I don't know much about the whole turbo thing this is my first VW, and I don't know if anyone has posted this question before. But has anyone tried having it installed at a shop to see if they have a solution for this problem. If so what have they told you.
[HR][/HR]​
The install of the Turbo Timer is not the problem, it's having it work in conjuction with the oem alrm. Meaning have the alarm turn on after the turbo timer turns off. That is the major problem that the 02 are having. I'm sure you would not want to walk away from your car knowing that it would not be protect right...so that's why we have been trying to come up with a solution to this problem. I'm also tring out a few things to see if we can crack this thing. If anybody comes up with the solution I hope they share it with us http://****************.com/smile/emthup.gif
1 - 9 of 9 Posts
