Did a little research on the Turbo Timer install procedures on 2002 1.8t's. Apparently it can be done but there are two existing problems:
1) your airbag light will remain on because you are splicing into it's wiring
2) your alarm will not arm until the turbo timer is done idling your car
pls. correct me if I am wrong on any of those points. what i need to know is:
1) has either one of these problems have been fixed?
2) will the problem still exist with aftermarket alarms?
Thanks in advance.
Thanks in advance.
