1 - 3 of 3 Posts
I have a few questions for this install...
1) Is it possible on any A3?
2) If I install one, will it affect my factory alarm?
I've heard talk that it will affect the use of the factory alarm...I DO NOT have keyless entry, so when I shut my car off with a TT in place, can I still lock my car and walk away with no trouble?
3) How hard is the install/wiring?
Any info from you guys out there that currently have them in your ride would be greatly appreciated! Thanks
Re: Turbo Timer install questions for a 2.0T (SoLo2pointO)
yea ut will work in any a3. about the factory alarm i dont know. i have an aftermarket alarm and i can not lock my doors with the timer running http://****************.com/smile/emthdown.gif . that really dont bother me its a small price to pay. as far as the install if you know what your doing the yes. its really not that hard. but if you mess up then you run into big problems such as.... the car not starting.
Re: Turbo Timer install questions for a 2.0T (turbojeta3)
I could really care less about the alarm, I just wanted to make sure that I could at least LOCK the car, once I took the key out of the ignition, and then after the TT shut off, it might arm itself? The instal doesnt look hard at all...
I just want to be sure I can get around the alarm issue...
1 - 3 of 3 Posts
