[url]http://www.extremepowerhouse.com[/URL]
Why shop with us?
Lowest Price Guarantee: We do our best to always have the lowest price on our website, but if you found an even lower price somewhere else let us know. We will match the other price and thrown in an extra $25 store credit towards your next purchase.
Financing: We offer 6 months no interest financing. Get the products now, pay later. You can at anytime pay the full amount or make partial payments during these 6 months. If after 6 months, you still have balance remaining on your account there will be a minimum monthly payment with interest applied, subject to credit approval.
Customer Service: We offer the best customer service, period! Don’t take our word for it, check out what our customers have to say about Extreme Power House https://www.x-ph.com/customer-reviews/
Hours: We are open 7 days a week from 8 AM to 11 PM Pacific Time.
Contact us: For any questions you can pm / email Mike@x-ph.com or call 725-221-5267. If you contact us during business hours, expect a reply within the hour. If you contact us outside of the regular business hours, expect a reply within 6 hours.
Chat: Looking for an immediate response to your questions? Go to our website www.x-ph.com and use our chat functionality.
Payments: You can make a purchase directly on our website www.x-ph.com or give us a call at 725-221-5267 and we can process your order over the phone.
Shipping: Expect to get a tracking number from us same day of your order completion. We try our best to get the products delivered to you ASAP. We ship items using USPS, UPS and FedEx. Contact Mike@x-ph.com for expedited shipping options.
Inventory: We stock all the popular products at our Las Vegas warehouse. If item is not in stock, we will get it drop shipped to you directly from the manufacturer’s location.
XPH Rewards: We now offer Extreme Power House loyalty points to all our loyal customers. Earn 1 point after every $1 you spend with us. Earn more by sharing our website on social media and referring your friends.
Newsletter: Join our newsletter for the latest XPH news, exclusive deals, group buys and coupon codes. We also offer exclusive newsletter flash sales.
Order Link
https://x-ph.com/turbo-transformer/
What is TURBO TRANSFORMER?
Turbo Transformer is a Bluetooth enabled piggyback boost controller for turbo-charged engines. It increases boost by intercepting one or more pressure sensor(s) on your engine.
What can I do with the smartphone app?
Using our free smartphone apps, a user can adjust the device settings and monitor the boost pressure. All devices are configured for a 2 psi gain when they ship. Custom mode allows the user to go up to 4 psi as well as fine-tune the mapping by adjusting all three attributes; base, delta and slope. The user may also choose to reduce the boost pressure by selecting Max-Eco mode in order to increase fuel economy. Hybrid mode allows increased fuel economy and boost pressure in the same configuration.
Will Turbo Transformer lean out my engine?
All modern turbocharged engines have a wideband O2 sensor that runs off the MAP sensor. Your ECU realizes the extra air mass and adjusts accordingly.
Where can I download the Turbo Transformer app?]
You can download the Turbo Transformer app for free on your Android or Apple smartphone from the Google Play store or the Apple App Store; respectively.
Does the module have an extra option to turn it on and off?
Yes, Turbo Transformer is Bluetooth enabled. Using a smartphone or a smartwatch, you can select Stock mode to restore factory performance. In addition, the device also ships with a bypass plug, to physically bypass the electronics in case of emergency. This way, the user is not forced to uninstall the device on the side of the road in case of a rare failure.
Warranty info
- 1 year warranty
- 14 days money-back guarantee. try it, if you do not like it we will take it back
Setup
- Ignition on , engine OFF
- Open the Turbo transformer Bluetooth app
- Select connect
- Click on settings, then select Zero to calibrate the unit (you only need to do this step once. No need to calibrate the unit every time you turn on the car)
Base PSI:
This is the PSI level at which the tuner is active. when your boost is below this PSI, the unit is not active and the car is running at stock power
Delta PSI:
This is the maximum amount of PSI the unit will be adding to stock. Its set to +2 PSI by default but can be increased to +4 PSI (please use with caution)
Slope (Rate):
- This value dictates how fast you want the unit to add boost
- Slower Boost increase will result in a smoother power delivery
- Faster boost increase will result in maximum power and responsiveness
Graph:
- The X axis is your stock boost. The Y axis is what the ECU is reading
- The grey line is stock power (X and Y will always be equal)
- The white line is your current map
- The red line is your custom map
Power Modes
- Power Default
- Max Eco
- Hybrid
- Custom
Power Default
- The default map is +2 PSI
- When X is 16 PSI, Y is 14. This means when you car is pushing 16 PSI, your ECU is reading 14 PSI. It will add 2 more PSI to get to the 16 PSI target boost resulting in an actual PSI of 18.
- Note: the tuner is not active till boost reaches a set PSI value (Base PSI). In this case its 11 PSI
Max Eco
- This map is the opposite of default power
- The ECU read value is higher than actual boost, which results in the ECU lowering the PSI
Hybrid
- This is a very unique and interesting map.
- Its on ECO settings when boost is lower than your base PSI & on Default Power settings once boost exceeds your base PSI
Custom
- In this map, you get to control the base PSI, delta PSI and slop rate
- Please use with caution
