1 - 2 of 2 Posts
well lately no one has came up with an answer, is it the horizontal way where or the vertical way, ive tried both and dont think theres a diff, but i dont know cause i dont have a boost gauge, i like it the horizontal way cause i can put my engine cover back on but the vertical way i haev to leave it off.
Re: TURBOXS BV CORRECT INSTALLATION (zack123082)
Probably doesn’t matter as you can run the OEM DV either way. But you may want to consider the design of that particular BOV. Does it use boost to help hold it close or just spring pressure? If its just springs pressure then it doesn’t matter.
1 - 2 of 2 Posts
