My turn signals recently stopped working....For a while they didnt work very well if you just switched the lever up or down, but if I pulled lightly backwards on them (as if to turn the high beams on but not pull back all the way) the signals would start to work...Now that trick doesnt work any longer. I just replaced the signal stalk out of a parts car that I know the turn signals work on...put it in my car and they still dont work. All the bulbs work...The emergency lights flash. When I hit the signal, the dash light stays a solid non-blinking green and no exterior signals turn on. When the stalk is in the 'neutral' position, the dash turn signal light is still on, but a very faint dim green. Any quick help would be appreciated. This is starting to piss me off
