1 - 3 of 3 Posts
Hi all, I have a 88 16v GTI and I have a turn signal problem.
When I am driving around, my turn signal LED is glowing dimly.
When to move the turn signals to left or right, it glows solid bright.
I can turn on the hazards and all 4 lights flash like they are supposed to (and no burnt out bulbs).
Any suggestions?
i had the EXACT same problem. Dont waste your money bringing it anywhere. It IS your turn signal switch. You can get one for 30 dollars shipped from stopshopanddrive.com. all you need is a 24mm socket to get the steering wheel off, and 2 screw drivers. Super easy only takes 10-15 minutes to do. I am 100% positive this is your problem.
Re: (vdubmatt)
I had a similar problem, replaced the turn signal switch, and all my problems went away! Very easy to do! http://****************.com/smile/emthup.gif
Omega
1 - 3 of 3 Posts
