1 - 12 of 12 Posts
Ok, so my turn signals will not work. When the stalk is in the "off" position, my turn signal light glows. When I move the stalk up or down to turn on my blinkers, the light comes on and stay a constant green. I checked the fuse and it is fine. I also checked what I thought to be the hazard relay and no luck either. What can I do to fix this? TIA
Pic for views:
Re: Turn signal problems (Speed Racer.)
had the same problem i started with the haz switch because they work together when i changed the switch still that steady green then i changed the flasher relay in the #6 spot on the fuse panel that was it they started to blink i previously ordered all three parts but it was the flasher relay got a extra stalk and haz switch now good luck
Re: Turn signal problems (hondasport2000)
same problem here. . .
checked fuses
replace hazard light switch
replace hazed flasher relay
checked all bulbs
next step. . .check signal light switch on column.
p.s. also missing backuplights!
anyone figure this out yet?
1 - 12 of 12 Posts
