1 - 2 of 2 Posts
my green turn signal light in the dash lights up dimly green. when i turn the stalk to signal it stays solid green either side. but wheni switch on the hazards they work. they turn on with the headlamps as well..
Re: turn signal Q (bpfoley)
I had a similar problem when I bought my car. Check the tail light blocks for any signs of shorts, corrosion, etc.
At some point one of the tails corroded. I spliced in a good connector, replaced the block and she worked like a charm.
1 - 2 of 2 Posts
