Turned on heater today....sounds like busted RC racer under the golve box?? What the heck is it?
371 Views 8 Replies 7 Participants Last post by  corrado4lifechick
I was driving on the highway today sandwiched between a big old truck in front of me, and a semi-behind me. I go and turn the heater and blower on...turned it on a few minutes before hand, and then it sounds like my front right wheel is about to fall off. The noise sounded like a vacuum cleaner with something stuck in it (high pitch/grind...low pitch/grind, repeat) or an R/C racer with one messed up motor. I turn off the heater/a/c unit and realize the sound stops. Start it up again, and there she blows/screeches.
The heat still blows, but the sound has me worried. The sound seems to be coming from underneathe the glove box?
Also, I barely run the heater, b/c it smells like exhaust fumes (assume it's an exhaust leak somewhere) and the a/c was out this summer (again, bought it that way).
I've done a 'search' and read about the heater core recall...but isn't that just for leaky heater cores? I'm not positive, but I don't think mine 'leaks'...just makes a terrible whiny/grinding/sucking sound.
Help?!
GameDay
See less See more
1 - 9 of 9 Posts
Re: Turned on heater today
Bearing in the heater fan has gone bad
Mine does the same thing http://****************.com/smile/emthdown.gif
See less See more
2
Re: Turned on heater today (bitchin'corrado)
Might have just sucked up a busted part too. You said you smell exhaust fumes, how strong are they? Check to see if they go away if you turn the air to recirculate instead of fresh air.
Re: Turned on heater today (CorradoKidd)
I have a good fan from Corrado with a/c option if you need it.
$45 shipped.
Re: Turned on heater today (KinetikSLC)
its a fair price http://****************.com/smile/emthup.gif as long as the noise isn't caused by a leaf
See less See more
2
Re: Turned on heater today (G60ING)
Where the heck is the fan for me to check? I did notice that there were a couple of leaves on the passenger floor that I hadn't noticed before
Do I have to take the dash apart?
And Chris, thanks...I'll let you know once I find out the problem
GameDay
See less See more
2
Re: Turned on heater today (GameDay)
go under your hood on the passenger side there is a black plastic thing with mesh on top remove that and vacuum all the crap out i did this and no more noise (mine was acting like a leaf grinder there was so many leaves in there)
Re: Turned on heater today (brilliantyellowg60)
Thanks! I'll try it tonight!
GameDay
See less See more
hey...mine was doing that same exact thing....but well.....now it doesn't and i'm not complaining but it's just a lil weird that it just stopped after doing it for weeks. i guess my c loves me so much it fixed itself
See less See more
1 - 9 of 9 Posts
