7
Re: twincharged, oh yeah, where can i find more info. (sirhcorrado)
Well I don't understand why it would be better to have the G60 first. The turbo should spool just fine first as long as theres a BOV. I think go go green golf said it would be silly to think running a turbo into a SC would double the thermal load. I hope he misspoke cause %36 efficanty causes a lot of heat. BTW a roots blower is %40 efficant, you know like the ones they use on top fuel dragsters
!! Just give this a thought, a small turbo will spool early, the G60 puts out more boost at higher rpm's. The effect I'm looking for is the same boost at all rpm's, not so much boost that the motor needs forged, cryo, nitrited,and shoot peened everything
I am not rich
SO lets look at a T26 feeding a new G60. At low rpm's the turbo is spooled and and is at peak efficanty but the G60 isn't putting out much boost and there for not much secondary heat. At higher rpm's the G60 is putting out the majority of the boost so the turbo backs off and therefor less heat. Because the turbo is small it would put out a lot off heat, trying to put out a lot of boost at higher rpm's, but like I said the turbo doesn't need to because the G60 is putting out the majority of the boost
So lets take a look at the plans for my project
I have a golf1 with cowl induction(metal is welded at the sides). 2" lift at the back of the hood. I'm going to take the raintray out to make room for the stock IC (passat) and also mount a starion IC with two radiator fans drawing air in and blowing down at the turbo (TD manifold mounted up side down). The T26 turbo feeds the stock IC then comes over the motor (hood is lifted) feeds the G60 goes back over the motor to the starion IC into a BOV right by the throddle. the total lenth of tubing should be less than the stock passat
Any one want to try to figure out the best way to deal with the bypass valve
