I have two 034 "ECU32" fuel only stand alone EFI systems. Tach reference is taken from hall sender in distributor. I have 2 units for sale, I can load either one with a 1 bar or 2.5bar "MAP" pressure sensor, (2.5bar would be for turbo applications).
This is a "standalone" EFI system that uses modern solenoid injectors, it will operate in closed loop mode with an oxygen sensor, it has adjustable mapping for best performance, you can also remove the CIS airplate and airbox that is a big restriction on most cars.
$325 for the new one $275 for the used one + shipping OBO
Please PM or email me for more infos at type85 at gmail dot com.
Here is the manual:
http://www.redlineweber.com/html/Fuel_Injection/Docs/ECU32_PROD_SHEET.pdf
Here is the manual:
