I've got an appointment to have a shop look into this but though I would pose the question in case anyone had any preliminary ideas.
Recently, my car has started sporadically sputtering when under light load and between 2k-3k rpm's. At first I thought it was a coil pack failing but it never threw a check engine light. After a couple of weeks, I've also noticed that it seems to do it more frequently when I am approaching 1/4 tank of gas or less.
Part 2 of this is I've pulled two soft codes. P0341 - Camshaft Position Sensor Implausible Signal and P2293 - Fuel Pressure Regulator Valve Mechanical Malfunction. To reiterate, these are soft codes, no check engine light. Both are listed as "intermittant". Fault frequency of 0341 is 10 and 2293 is 2. Both have date stamps of within two days of each other. There were no other stored codes.
Car is chippped with APR stg1
Neuspeed cold air intake
Timing belt done at 80k (about a year ago)
Cam follower was changed at 50k and again at 75 with no issues noted
Car now has 92k miles on it
Any ideas?
Any ideas?
