1 - 15 of 15 Posts
The car will be coming apart after H2O so I have a few parts for sale. Please no Low balers I wont sell it just to get rid of it. Buyer pays cash in person or Paypal (buyer pays fees and shipping). If item is available now it will say in the description
All parts are first come first serve and deposits will be accepted to hold parts, if any issues arise refunds for them will be give back. PM for details.
Updates will be posted periodical follow this thread for what is sold/deposit and any new items. Feel free to ask questions on parts, all pricing and sales please PM.
PACKAGE PRICING AVAILABLE
1. ForceFed Engineering Big Turbo kit - $3500 - Deposit Made
- FFE vband tubular manifold - 1.5inch SS construction with v-band flange - No wedge plates TRUE stud install.
- FFE vband down pipe with recirculation - 3" SS V-band construction - Fits Eurojet turbobacks directly or I can include a SS midpipe with cat to fit a Unitronic catback for and additional cost
- Oil lines w/ oil pan (only TSI needs pan, FSI an adapter on the pan an you can hook it right up.
- Tial MVS v-band wastegate 38mm
- Precision CEA 5858 ball bearing turbo, SP 4" ported housing, .64 A/R vband in and out hotside.
- First piece turbo outlet piping. - 2.5" aluminum (slight adaption to OEM style ICs, minor)
- Under 10k miles on the kit and never raced
2. Built 02Q 6MT Transmission GLI Gears - $2100 - Deposit Made
- Fits 2.5L, FSI, TSI and 1.8t
- GLI Longer Gears will do 130mph in 4th - perfect for drag racing
- Wavetrac LSD
- USP Shift Forks
- USP SS clutch line
- Less than 20k miles on the wholes trans (trans itself and upgrades) and never raced
3. OEM shift boot and Knob assembly MK6 GTI - $75 - Deposit Made
- Non golf ball style 6 speed
- Perfect for cleaning up your damaged or worn one, updating to a newer style
- Perfect for 6 speed swaps
4. OEM 6 speed shifter assembly MK6 GTI - $150 - Deposit Made
- Comes with cables
5. OEM 6 speed Axles and starter for 6mt swaps MK6 GTI - $375 - Deposit Made
- Axles and starter and misc parts to complete the swap
6. Cayanne/Touareg Rear Caliper mounts for FWD - $500 - Deposit Made
- Mounts only
- Aluminum Version
- Will help with hardware specs
7. Clutchmasters Fx400 kit - $400
- Steel Single Mass Flywheel
- ARP bolts
- 6 puck sprung design
- With throwout bearing - less than 10k on it
- Clutch has 30k miles on it and holding no issues at all
8. Pre drilled final drive Ring Gear for Diff installs- Available now - $150ea
- Keep your diff in tact for part out/going back to stock in the future
- Fits, 02Q 6MTs - GLI (some, shorter gears), EOS, Bettle, GTI, Golf R
9. 02Q FWD case and input shaft and 2 main shafts for parts only - Available now - $500
- case is in great shape
- input shaft and 2 main shafts include
- 4th and 6th gears damaged
- for parts and builds
- 2 sets of 1-2, 3-4 shift forks
10. Stock GTI/GLI IHI turbo - Available now - $350
- like new less than 6k on it
11. OEM rear sway bar - Available now - $75
12. Nuespeed rear sway bar FWD - Available now - $150
13. OEM Spare Wheel and Tire never used - Available now - $100
14. OEM GTI Front brakes - Available now - $300
- Rotors
- Calipers
- Pads
- Brake hoses
- Package deal for front and rear - PM me
15. OEM GTI Rear brakes - Available now - $300
- Rotors
- Calipers
- Pads
- Brake hoses
16. OEM front sway bar - $75
17. OEM Struts, shocks, and springs - Available now - $300
- 6k miles on them
18. Unitronic GTI Cat-Back - $650 - Local Pickup only
- The best GTI exhaust on the market
- Perfect fit
- Aligning and sealing V-band connections
- Less than 10k on the system
- My review http://www.golfmk6.com/forums/showthread.php?t=67622
19. OEM brand new manifold wedge blocks - Available now - $50
20. OEM brand new GTI carpet floor mats - Available now - $50 - pickup only
21. OEM Updated hood blanket - Available now - $50 - pickup only
https://lh5.googleusercontent.com/-CaUQZEEFDRY/VAG03PCateI/AAAAAAA****/mqE6L4RDdJk/w505-h673-no/IMG_20140830_072613.jpg
22. OEM IHI MK6 Turbo 6k miles never tuned - Available now - $350
23. OEM GTI Steering Wheel Multifunction Red Stitched Very Good Condition - $350
- No Airbag
25. OEM 6 speed MK6 GTI Aluminum Pedals - $200
- Full Gas pedal
- Full clutch pedal (clutch cylinder available and lines)
- Brake pedal
- Perfect for auto to manual swaps or for aluminum pedals
26. OEM intercooler hoses - $35
- Like new, 6k miles
- Missing the Top side green oring
27. OEM GTI rear valance for twin tip exhausts - $50
Can i call dibs on the w/m system now?? :beer:
Discussion Starter · #7 ·
Does the tranny include a clutch?
It does not include one but packages are available, I have an oem one with 6k and a Clutch Masters FX400 with 30k that holds perfect still and can be rebuild later for the fraction on a new clutch.
Discussion Starter · #8 ·
PM me if you are interested
Just got a deposit this afternoon on the entire swap
Okay. If it falls through, I'm your buyer.
And if the sale on that built gearbox falls through, I'm your buyer even if the swap doesn't :beer:
Discussion Starter · #14 ·
Updated again
Also to answer a PM question I received the 02Q swap is 100% complete to ge from a 5 speed to a 6 speed except for the clutch since the clutch is an 8 bolt. I do also have all the parts to go from and auto to a manual 6mt (pedals and clutch cylinder.)
1 - 15 of 15 Posts
