1 - 20 of 27 Posts
well we were putting all new rotors on my car and got both front done and 1 back done then the othe side would not screw back in (the piston) it would just trun and would not go in so is my caliper shot ?sucks the big one took us soooo damn long to get the back one on there pita
Re: uhhhggg caliper (derek95)
put an old brake pad or flat piece of thin wood over the piston and squeeze it with a clamp, it's always worked for me. i've never had to do the brakes on any of my dubs though
Re: uhhhggg caliper (slowmowfoe)
well for the back brakes i need to twist the pistons as i push the front i just clamped
Quote, originally posted by derek95 »
hmmmm, there may be a special tool or something, aybe try the braking forum.
wish i could help you more
Yes, you must turn and push the piston back into the caliper.
Discussion Starter · #6 ·
Re: uhhhggg caliper (GriffinMoss)
yes i know this if you read my post you'll see this i got one back one in fine with the tool but the other one won't go in it twists but won't go in
Discussion Starter · #7 ·
pictures to get some hits
sitting on stands till i can get a new caliper
the new rotors
Discussion Starter · #9 ·
ok people i know your trying to help but i have one side in already the cube works fine for me i don't need the other tool
have you check the brake line to make sure it isnt clogged or anything like that. Try bleading the brake itself. Maybe that will work http://****************.com/smile/emthup.gif
Discussion Starter · #11 ·
Re: uhhhggg caliper (slammed dub)
yea finally after 9 hours on it (the hole car) we decided to take the entire caliper off the car and put it on the bench we still couldn't get it to budge
Time for a trip to autozone man
Good luck with it though.
I know its not what you wanna hear man but its the only thing I could think of
Discussion Starter · #16 ·
yea i know i need one lol i called a couple places but i guess its not a highly needed part around here on monday i'll go to vw grave yard and get one
Bro if you were down here you could pick up one for like $15 or$20 or so. Along with it will be the rear section still completely attached but cut about 6 inches into the rear beam.
Discussion Starter · #18 ·
i should be able to get a nice deal here though it will only be the caliper the guy kicks major as$
Thats good man at least you got a hook up on it. http://****************.com/smile/emthup.gif
Ive been there and done that before and it suxs major balls
Discussion Starter · #20 ·
should've seen the old rotors ..on the back we had to grind off a lip on them they were soo mesesd up
1 - 20 of 27 Posts
