1 - 4 of 4 Posts
Discussion Starter #1
2008 Rabbit 2.5 have had idle problems suddenly-blinking check engine light -codes- air injection incorrect flow- intake air leak- bank one too lean- multiple misfires all cylinders- have not located leak yet but I disconnected MAF sensor then started engine no rough idle- in park slightly higher idle but in drive ran great - without MAF do I lose gas mileage and/or can it cause damage??? Or could I put on cold air intake??
Discussion Starter #2
MAF or housing does not appear to be dirty but did find wiring harness repaired prior plastic cover with exposed wires where splicing was done
I would fix the wiring and maybe even replace the MAF.
1 - 4 of 4 Posts
