1 - 13 of 13 Posts
i finally finished trimming the dash to fit in my Rocco. I had to cut about 3-4 inches off. As of now I just screwed the sides of the dash in. I got it trimmed pretty close.
I need to find a couple more mounting points. The top needs to come up about an inch. BTW I used the rocco dash as a template to figure out how much of a curve I need the trim the dash. Im still trying to locate g60 swtiches, MFA out of a rocco or early A2 and some other stuff. I tryed to see if the rocco switches would work in the dash. But they are about 1/2mm too long. I guess I can make them work if I have to. But I dont think the headlight switch would fit. Since its bigger than all the other switches. I tryed to fit the G60 tilt steering column but it doesnt fit. If I wanted to do alot of welding I guess the A2 pedal bracket and steering column bracket would work. But I dont have access to a welder nor do I know how to use one. Anyway here are a couple of pics of the progress. I'll have more updates later.
Re: Update 2(g60 dash) (D_Kraus_Dirtbiker)
looking good...
can't wait top see it finished
http://****************.com/smile/emthup.gif Big thumbs up for undertaking a dash job http://****************.com/smile/emthup.gif
especially when u fit the wrong one
R you adding the seats too..
Re: Update 2(g60 dash) (hoodita)
The only reason I decided to do this is cause my rocco wont be coming out of my garage till this december. So I have plenty of time to do whatever. So by Dec. im hoping to have either a new 1.8 or 2L16v plus some engine mods, suspension,G60 brakes,and a bunch of other stuff. O and im going to take the stock seats out and get a pair of Sparco Milano's(hopefully). BTW I think the only way im going to get gauges in where the cluster is suppossed to go is make a custom panel with custom gauges. Its going to take me a while to figure that part out.
[Modified by hoodita, 7:00 PM 2-10-2002]
Went to the local VW jy this morning. There's a 90-ish G60 shell there with most of the dash trim and switches still in it (IIRC)... Gauge pod is still in it as well...
I'll try to help if I can. I'm in New Mexico.
Oh, and good job fitting the dash! Very cool...
Discussion Starter · #8 ·
Re: Update 2(g60 dash) (Gewinn)
quote:[HR][/HR]Went to the local VW jy this morning. There's a 90-ish G60 shell there with most of the dash trim and switches still in it (IIRC)... Gauge pod is still in it as well...
Oh, and good job fitting the dash! Very cool...[HR][/HR]​
Thanks for the offer. I think I found someone that has the stuff that I need. But if for some reason they got rid of it. I will defintely let you know.
Discussion Starter · #10 ·
well I mounted it up better. The dash isnt going anywhere. Now all I need is the rest of my parts. Plus I need to dye the dash black so it matches the rest of the interior.
Re: Update 2(g60 dash) (akiwak)
Ummmm I may be wrog but wouldn't it have been much easier to Dye it while it was out of the car?
Swweeeettttt Job, looks amazing compared to what is in my car
Discussion Starter · #13 ·
Re: Update 2(g60 dash) (HowlinMonkey)
quote:[HR][/HR]Ummmm I may be wrog but wouldn't it have been much easier to Dye it while it was out of the car?
http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif [HR][/HR]​
yeah im taking it out to dye it.
1 - 13 of 13 Posts
