upgrading braking
446 Views 7 Replies 4 Participants Last post by  Eric16v
can someone tell me what i will need to upgrade my stock 92' stock 1.8L GTI braking system to the G60 Corrado braking system??
what exactly is it that i will need besides rotors and brakes???
See less See more
2
1 - 8 of 8 Posts
Re: upgrading braking (ruderacer)
what size are your brakes now? If they are 10.1" then all you would need is the carrier bracket. Your calipers and pads will work, but need rotors.
Re: upgrading braking (Eric16v)
i actually think they r 9.4's and my mechanic told me see if i can get the 11's from a g60 and my stopping will be on point http://****************.com/smile/emthup.gif
See less See more
if you have 9.4" you need a 10.1 or 11 hub assembly from a later 89-92 GLI or G60 or 90(?)-92 16v gti
quote:[HR][/HR]if you have 9.4" you need a 10.1 or 11 hub assembly from a later 89-92 GLI or G60 or 90(?)-92 16v gti[HR][/HR]​
No NA spec GTI came with the 10.1" fronts. 10/88+ GLIs did as well as A3s and B3s.
quote:[HR][/HR]what size are your brakes now? If they are 10.1" then all you would need is the carrier bracket. Your calipers and pads will work, but need rotors. [HR][/HR]​
Ah, yes, this is correct...one of the easiest brake upgrades i ever did...those were the days
See less See more
Re: upgrading braking (lucaq)
![HR][/HR]​
The 10.1" and 11" calipers are different and unfortunately he has an 8V GTI with 9.4" rotors so he needs the whole setup.
See less See more
Re: upgrading braking (vwpat)
!The 10.1" and 11" calipers are different and unfortunately he has an 8V GTI with 9.4" rotors so he needs the whole setup.[HR][/HR]​
The only thing different is the carrier, not the caliper. That is why g60, 10.1 and 11" vr6 brake pads are all the same shape.
See less See more
1 - 8 of 8 Posts
