Re: Upper Strut mount (vr6piloto)
Well you can replace the fender itself... I'd not sure though if that holds the strut or if the strut is on a frame part. I must be a frame part.. mounting the strut to the fender is silly. I'd still think welding would be OK. Sheesh, the flippin frame is welded together, so why wouldn't a crack repaired via weld not hold up. Second opinion is required here. Try another body shop. You should call Crosby Audi/VW here in KW. They have a reputable body shop in the dealership. I'd guess there opinion on this issue wouold be worth the call.
