Greetings folks. I'm curious what you 1st gen guys use for performance improvement with the upper strut mount? I know the very earliest cars had the rubber part that could be removed and VW Motorsport had a higher durometer replacement, but I also know those mounts are incredibly difficult to come by. Eurosport sells polyurethane, of which I have a set, however, for MY application, even though they fit into the mount on the top side, they're too tall overall, and would need to be turned down on a lathe, which I do not have. Also, I wouldn't know how much material to remove(I suppose they could simply be made the same height as the factory rubber one.) ALSO, those urethane bushings are HARD. Might as well be delrin. The Fox had very similar mount and I read some years back it fit and was slightly higher durometer. I just purchased two different brands of the Fox version to try. I've also looked at Porsche 944 mounts, but they're a bit too spendy to just experiment with(Fox part, ~$5; 944 part,~$110).
For the record, this is for my autocross prepped Super Beetle. I started a thread about this in the Vortex aircooled section several years ago, but the only response I received was suggestion of urethane. I'd really like to explore harder rubber options before I resort to urethane.
If any of you have given this any thoughts for your Mk1 car, I would appreciate any input
Thanks
H2OSB
Thanks
H2OSB
