1 - 9 of 9 Posts
I'm in the process of swapping my VR..into another shell.......
As preventive maintanence, I replaced the main seal on the tranny, spring for the lever, and throw out bearing.......I ordered the throw out bearing lever, BUT they say its on national backorder?! IS THIS TRUE?
I NEED ONE BECAUSE MINE HAS HAIRLINE CRACKS IN IT! AHHHHHHHH
oh..and i have to have this swap done by Next monday............
Re: Urgent!:... Throw out bearing lever...on nationwide backorder?!???? (VRpoweredA2)
who have you called? have you called the pottermans, vwparts.com? just a suggestion http://****************.com/smile/emthup.gif
now thats a load of B,S. - backorder??? Does the O2A lever fit the O2J?
P.S. - you NYC guys go through shells/swaps more often than most people change oil
Re: Urgent!:... Throw out bearing lever...on nationwide backorder?!???? (PAGTI91)
if the 4cyl. o2a lever would work I go one I could send you out tomorrow tues. cheap http://****************.com/smile/emthup.gif
Quote, originally posted by PAGTI91 »
you ever drive in NYC?
This past summer I had a lever go bad in a 95 passat vr6. The dealer said the same thing about the back order so I ordered one for an 02J tranny and it worked just fine.
Re: Urgent!:... Throw out bearing lever...on nationwide backorder?!???? (AnotherA2VR6)
i have one in CT if you want to drive an hour to meet me halfway tonight there is a gtg in milford CT exit 39b off 95
Discussion Starter · #8 ·
Re: Urgent!:... Throw out bearing lever...on nationwide backorder?!???? (kevinmacd)
Thanks for all your help guys...but I found a friend of mine locally who had one laying down.
I spoke to Dave from Germanautoparts...he mentioned that the part number i was looking for was indeed an O2J tranny part.....He says its the same part as the O2A...what happens, he explained, is that when a new car comes out...and a particular part fits another model application, the newer part # supercedes (sp?) the old number...so that O2J # is also for an A3 VR tranny as well. http://****************.com/smile/emthup.gif
Re: Urgent!:... Throw out bearing lever...on nationwide backorder?!???? (VReihenmotor6)
Quote, originally posted by VReihenmotor6 »
I'll have to say no to that...S.I. is as close as I have come as far as driving my own ride...Aurthurkill BLVD isn't that bad
...props to you guys for keeping phat dubs in the city..I'll say this, I have seen a few sick Mk2's in NYC each time I have been up there, for real! http://****************.com/smile/emthup.gif
1 - 9 of 9 Posts
