Re: used search for that info on 20k service. no luck, linkie anyone? (shawnpm)
Vehicle Maintenance Schedule
Year: 2004 Engine: 3.2LVR6
Miles 5 10 20 30 40 50 60 70 80 90 100
Kilometers 8 16 32 48 64 80 96 112 128 144 160
Engine Oil - change X X X X X X X X X X X
Engine Filter - change X X X X X X X X X X X
V-belt/Ribbed Belt - check X X
Spark Plugs - replace X
Air Cleaner - replace filter X X
Windshield Washer Fluid - check level X X X X X X X X X X
Brake System - check damage/leaks, pad thickness, fluid level X X X X X X X X X X
Wheels - rotate from front to rear X X X X X X X X X X
Battery - check electrolyte level X X X X X X X X
Engine - check for leaks X X X X X
Pollen Filter - replace X X X X X
Cooling System - check level X X X X X
Transmission - check for leaks X X X X X
Tires/Spare - check condition X X X X X
Driveshaft - check boots X X X X X
On Board Diagnostics -check Diagnostic Trouble Code memory X X X X X
Door Hinge - lube X X X X X
Headlights - check and adjust if necessary X X X X X
Exhaust System - check for damage and leaks X X X X X
Sunroof Frame - clean and lubricate X X X X X
Road Test-check system functions during and after X X X X X
Power Steering - check fluid level X X
Front Axle - check dust seals, ball joints, tie rods X X X X X
Haldex clutch: Change oil X X
The intervals shown in the table are based on vehicles operating under normal conditions.
In the case of severe conditions, such as extremely low temperatures, excessive dust, etc., it is
necessary for certain operations to be carried out between the given intervals. This applies
particularly to engine oil changes and the cleaning or replacing of the air cleaner filter element.
Modified by roadrunner469 at 2:57 PM 9-10-2005
