1 - 16 of 16 Posts
I have seen that the majority of people tap into the FPR hose to get their boost readings. However, I have also read where the vacuum line from the DV can be used.
First Question: Are there any other places to get a boost reading?
Second Question: Which will give the most accurate reading?
My techincal know how...or lack thereof
prevents me from making this decision on my own. Thanks in advance for all info. http://****************.com/smile/emthup.gif
Re: used search no help...boost gauge install question (gotpsi)
bump
Re: used search no help...boost gauge install question (FrankiEBoneZ)
quote:[HR][/HR]Tap the FPR line by the manifold.[HR][/HR]​
Re: used search no help...boost gauge install question (RoninTT)
Quote, originally posted by RoninTT »
FPR line goes directly to the manifold. It is probably the most accurate. Do not use the DV line
Why not?
Because of the answer he already gave you
Re: used search no help...boost gauge install question (APRTUND)
Quote, originally posted by APRTUND »
Where is the FPR? and the hose that connects to it?
remove the engine cover. you'll see a nylon braided hose coming off of it.
Re: used search no help...boost gauge install question (LeftCOASTpunK)
Answer:
The DV line goes through the N249 valve too, so it is not a direct connection to the manifold. Use FPR lne. N249 valve will keep the DV opened (leave the vacuum on it) until positive boost is requested.
1 - 16 of 16 Posts
