USP Motorsports presents | SPULEN Spul Engineering Dog Bone Engine Mount Complete Kits!!!
If you have already purchased an aftermarket dog bone mount insert, the Spulen Dog Bone Engine Mount is perfect for you. This lower engine mount is made from CNC'd aluminum and features a bushing far stronger than stock. Designed to work with all mount inserts which use the factory lower mount, the Spulen Dog Bone mount is the final piece in ungrading your engine mounts.
What's Included:
- Billet lower engine mount
- New Hardware
* The use of performance motor mount inserts will increase vibrations that are transferred to the cabin of the vehicle
** If you are a previous purchaser of a Spulen Dog Bone Mount insert please contact me for a special price on this.
CLICK HERE to order Please check for your particular applications on the product page.
Dog Bone Engine Mount kits are IN STOCK & ready to SHIP!!
Links To Kits:
If you do not have any sort of Dog Bone Mount here is your chance to pick one up!
Spul Engineering Dog Bone Engine Mount Kit (Street)
Go above and beyond a simple mount insert! Have you increased the power of your Volkswagen or Audi? Are you looking for smoother shifting? Either way this new dog bone kit from Spul Engineering (SE) is perfect for you. The SE mount insert works in conjunction with the OEM rubber bushings to provide a more rigid connection between the transmission mount and the subframe. Once the mount is installed, drivetrain movement is reduced and you will experience smoother shifts and less engine movement. Also included is a CNC lower engine mount complete with upgraded bushing to replace the weak factory mount. Installing the mount can be done in your own garage.
What's Included:
- Spulen Dog Bone Mount Insert
- New Hardware
Spul Engineering Dog Bone Engine Mount Kit (Extreme)
What's Included:
- New Hardware
Questions?
Email: [email protected]
Phone: (888) 755-7772
or PM me!!
