The coolant hose flange is located on the driver side of the cylinder head and connects the radiator hoses to the cylinder head. The factory flange is constructed from plastic and overtime begins to warp and crack leading to coolant leaks. Until now your only option was to replace the factory hose flange with another plastic piece, delaying an inevitable coolant leak.
Introducing the Lager Parts Cast Aluminum Coolant Hose Flange. Constructed from cast aluminum this part is a direct replacement for the factory coolant hose flange. The factory coolant temperature sensor and all factory hoses mate seamlessly to the Cast Aluminum Coolant Hose Flange. Each Lager Parts Cast Aluminum Coolant Hose Flange is cast from aluminum and then carefully machined to exact tolerances. For the performance minded enthusiast a blank sensor boss is located on top of the Coolant Hose Flange giving you the ability to drill and tap a 1/8th or 1/4th inch port for a gauge sensor.
Features:
Replaces factory number 06A 121 132AP and 06A 121 132AH
Available for:
*Fits both automatic and manual transmission vehicles.
Click Here for more details.
Factory coolant flange on left, Lager Parts Cast Aluminum Coolant Flange on right
Installed on vehicle
Features:
- Cast aluminum construction
- Includes new o-ring
- Lifetime warranty
Available for:
- 2000-2005 Volkswagen MK4 Golf and GTI 1.8T
- 2000-2005 Volkswagen MK4 Jetta 1.8T
