What im dealing with here is a damaged clamp. Normally, i would just grab a spare or order one from ATP or PAG or something. But this vband isnt what i would call typical. the 'vs' arent as thick as ones like we are used to seeing, but the angles are the same. there is a washer ab. 3/16" thick between the v's. So if i remove the washer and use a typical clamp then it wont tighten up because the assembly isnt wide enough for the clamp. and if i try to put a typical clamp on, it wont fit; as it isnt wide enough to accomodate the washer.
the brand name is nelson. it is marked DIV 89500.
I know that i can source one from Canada, but i dont know of a US supplier and i need this thing before friday
any help you guys may have would be appreciated.
TIA, Tank
TIA, Tank
