1 - 8 of 8 Posts
I've heard through the grapevine people are running 102% boost and 2 degrees of timing.
Anyone have any experience with using the V-Tune?
Re: V-Tune - What settings are you guys running. (snarbles)
Quote, originally posted by snarbles »
Close to accurate. I've had good success with 104% boost and 0.75 timing advance. As soon as the FMIC goes on, however, the timing will change.
I also run the N75J valve, FWIW
I'm at +.75% timing 106.xx boost and 105.xx fuel load increase using autolite 3922 plugs (one heat range colder). my timing is being pulled very little with this setup.
Discussion Starter · #4 ·
Re: V-Tune - What settings are you guys running. (WildRover)
ttt http://****************.com/smile/emthup.gif
How are you guys able to determine whether or not you are causing knocking. I do have a Vag-com, but have never tried to test for knocking yet.
Thanks
You can determine knock using the VAG-COM looking at Block 020, I believe. People have been saying a value less than 5 is "acceptable" for timing knock.
Hope this helps.
Quote, originally posted by WildRover »
APR told me that 5.25 and below is acceptable.
maybe APR will create a tuning document to help you guys out.
That would be very cool of them...
1 - 8 of 8 Posts
