1 - 9 of 9 Posts
Discussion Starter #1
Hey guys I just wanted to see what the proper vacuum at idle is for a 1.8T. Mine is at 15 now, but when I installed my boost guage it was around 20. I have a GIAC X+ flashed AWP, and a used Bailey's DV. Could it be the DV is worn out or is that just normal?
Thanks!
Re: Vacuum at idle? (MolotovMan)
I also have an upgraded Stratmosphere billet DV. Don't think that makes a difference though. Cheers,
Re: Vacuum at idle? (Quattro_ing)
I had an issue like this and it ended up being a small leak at the gauge. Just a thought http://****************.com/smile/emthup.gif
Discussion Starter #7
Re: Vacuum at idle? (Bluebomber)
Quote, originally posted by Bluebomber »
Thanks man, I had a feeling it could be that, I brushed it aside though because I didnt hear any hiss.
So you guys think it woudl be that instead of a DV with a weak seal?
Discussion Starter #8
Quote, originally posted by MolotovMan »
Well I just check at the guage and theres no leak, I'll check under the hood tomorrow at my T fitting.
Anymore suggestions guys?
I have my boost gauge T-fitting at the fuel pressure reg and lost all boost and vac the stock lines were dead cracked and leaking check right there fixed mine at idle i pull 20
1 - 9 of 9 Posts
