1 - 8 of 8 Posts
Re: Vacuum Supply Pump installation (HurleyManVw)
is that the thingie in front of the wheel on the drivers side?
if so I'd pull the wheel/ fender liner
Re: Vacuum Supply Pump installation (VReihenmotor6)
this is the pump at operates the locks, located in the trunk compartment.
It's pretty easy, one wiring harness and one tube connect to it. See your Bentley shop manual if you need further assistance but you shouldn't.
Re: Vacuum Supply Pump installation (Air_Cooled_Nut)
Thanks for the help, I have not recieved it yet so i haven't even looked at how easy it might be. I appreciate the responses. http://****************.com/smile/emthup.gif
The one in front of the wheel on the drivers side is part of the cruise control system. It helps to regulate a speed by keeping a vacuum. (more or less)
I need a Vacuum Supply Pump, where did you get yours? Mine doesnt work anymore...
Re: Vacuum Supply Pump installation (95mk3jetta8v)
Try Ebay, I just got one for $50. Does anyone know where this is located in a 97 Jetta? I must be blind, I can't find it
Re: Vacuum Supply Pump installation (dhavener)
Quote, originally posted by dhavener »
Right side quarter panel, behind gas door, above trunk floor, in front of tail light, behind trim panel
1 - 8 of 8 Posts
