1 - 4 of 4 Posts
Is there a place in one of the forums that lists the different codes used by the Vag-Com to program the autolock/ unlock/ honking options? For example, I want to disable autolocking of the doors. I want both doors to unlock when I push the unlock on the remote once. I do not want honking when the alarm arms.
Audiworld.com has a great list for my A6 that I took to the dealer to show them exactly what I wanted. I was hoping we had something here for the VWs.
Thanks.
Re: Vag-Com codes for programming alarm/ locks/ honking (LWLam)
Bump.. I have a list for Audi A4 (maybe other Audis too) - is it the same for the MKIV?
Eric
Re: Vag-Com codes for programming alarm/ locks/ honking (vwbora1)
Did you even try and find this on your own
Right from http://www.ross-tech.com/vag-com/cars/vwmkIV.html
46 - Central Covenience: -- KWP1281
Only on vehicles with power windows. VAG-COM fine. There are numerous options/ features that can be set.
Selective Unlocking:
Select Control Module > [Select]
[46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first four digits in the coding:
0025 - Two electric windows (2 door)
0409 - Four electric windows (4 door)
Look at the fifth digit in the coding:
6 - All doors unlock, Vehicle without power seat
7 - Selective unlocking, Vehicle without power seat
8 - All doors unlock, Vehicle with power seat
9 - Selective unlocking, Vehicle with power seat
So, if you have a 4-door with power seat and you want selective unlocking, 0409,9 = 04099.
Lock/Unlock Horn/Flash:
VAG-COM
[Adaptation - 10]
Channel (03..08)
Adaptation Value (1 = on, 2 = off)
Channel 03 Auto Lock/Unlock
Channel 05 Unlock, horn sounds
Channel 06 Lock, horn sounds
Channel 07 Unlock, turn signals flash
Channel 08 Unlock, turn signals flash
1 - 4 of 4 Posts
