1 - 1 of 1 Posts
Monday,01,February,2016,16:43:40:36028
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
VIN: 1VWBT7A31EC License Plate: WLFSBURG
Mileage: 38110km-23680mi Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
75 77
VIN: 1VWBT7A31EC
Mileage: 38110km-23680miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CPRA) Labels: 06K-907-425-V2.clb
Part No SW: 06K 906 070 J HW: 06K 907 425
Component: Simos12.2 H09 6867
Revision: --H09--- Serial number:
Coding: 001A0012242400170000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM18TFS02006K906070J 001005
ROD: EV_ECM18TFS02006K906070J.rod
VCID: 3147F7E660A5E6B6CE-8064
4 Faults Found:
16817 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 37387 km
Date: 2016.01.25
Time: 08:59:32
15369 - Bank 1; System Too Lean off Idle
P2177 00 [236] - -
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Mileage: 27344 km
Date: 2015.10.05
Time: 16:19:01
15031 - Bank 1; System too Rich at Idle
P2188 00 [096] - -
Freeze Frame:
15343 - Boost Pressure Regulation
P0299 00 [104] - Control Range Not Reached
Freeze Frame:
Fault Priority: 2
Fault Frequency: 209
Mileage: 16671 km
Date: 2015.07.03
Time: 12:00:43
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 09G-927-749.clb
Part No SW: 09G 927 749 B HW: 09G 927 749 B
Component: AISIN AG6 G3 109 2855
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_AU37.rod
VCID: 3851CAC283DF37FE89-806C
3 Faults Found:
22970 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 174
Mileage: 37387 km
22920 - Implausible Data Received from Parking Brake Control Module
U0417 00 [032] - -
22984 - Gear Shift Lock Solenoid Control Circuit
P0929 00 [032] - Implausible Signal
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: C54BC0F549220001A31403E9921B0041A0100012
VCID: 7EDD1CDAE97BC9CE03-802A
3 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 207
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.20
Time: 16:17:21
Freeze Frame:
Count: 3
Count: 13
Count: 20480
Count: 16390
Count: 33280
Count: 0
Count: 255
Count: 0
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 214
Mileage: 37387 km
Time Indication: 0
Date: 2016.01.25
Time: 08:59:32
Freeze Frame:
Count: 64
Count: 2
Count: 4608
Count: 67
Count: 49938
Count: 2835
Count: 3083
Count: 0
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 230
Mileage: 37413 km
Time Indication: 0
Date: 2016.01.25
Time: 09:22:08
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 51547
Count: 0
Count: 1
Count: 0
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 561 907 426 E HW: 561 907 426 E
Component: AC Manuell H02 0303
Revision: 00001K02
Coding: 0010001002
ASAM Dataset: EV_ACManu****ctGen2BHTC 001002
ROD: EV_ACManu****ctGen2BHTC_VW36.rod
VCID: 1D1F3B560C3D72D67A-8048
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: EF200E38902B08D4098800010600814002F1A00040801D20648060000C70
VCID: 78D10AC2CB5FF7FE49-802C
17 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 213
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.20
Time: 10:44:03
Freeze Frame:
Term 15 On
Voltage: 10.35 V
ON
ON
ON
OFF
ON
00897 - Windshield Washer Pump (V5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 37
Reset counter: 215
Mileage: 37387 km
Time Indication: 0
Date: 2016.01.25
Time: 08:35:04
Freeze Frame:
Term 15 On
Voltage: 13.60 V
ON
ON
ON
OFF
OFF
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 37
Reset counter: 215
Mileage: 37387 km
Time Indication: 0
Date: 2016.01.25
Time: 08:35:04
Freeze Frame:
Term 15 On
Voltage: 13.60 V
ON
ON
ON
OFF
OFF
00907 - Intervention load Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 4
Reset counter: 190
Mileage: 38109 km
Time Indication: 0
Date: 2016.02.01
Time: 15:23:04
Freeze Frame:
Term 15 On
Voltage: 11.75 V
ON
ON
ON
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 239
Reset counter: 230
Mileage: 31499 km
Time Indication: 0
Date: 2015.11.09
Time: 13:19:37
Freeze Frame:
Term 15 On
Voltage: 13.60 V
ON
ON
ON
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 230
Mileage: 36803 km
Time Indication: 0
Date: 2016.01.09
Time: 16:55:03
Freeze Frame:
Term 15 On
Voltage: 13.35 V
ON
ON
ON
OFF
OFF
01493 - Bulb for Blinkers; Front Left (M5)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.18
Time: 17:25:15
Freeze Frame:
Term 15 On
Voltage: 9.50 V
ON
ON
ON
ON
ON
01495 - Bulb for High-Beams; Left (M30)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.18
Time: 17:25:13
Freeze Frame:
Term 15 On
Voltage: 11.50 V
ON
ON
ON
OFF
OFF
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 206
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.18
Time: 17:25:13
Freeze Frame:
Term 15 On
Voltage: 11.45 V
ON
ON
ON
OFF
OFF
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.18
Time: 17:25:13
Freeze Frame:
Term 15 On
Voltage: 11.45 V
ON
ON
ON
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.18
Time: 17:25:13
Freeze Frame:
Term 15 On
Voltage: 11.45 V
ON
ON
ON
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 206
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.18
Time: 17:25:13
Freeze Frame:
Term 15 On
Voltage: 11.45 V
ON
ON
ON
OFF
OFF
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.20
Time: 10:41:59
Freeze Frame:
Term 15 On
Voltage: 11.15 V
ON
ON
ON
OFF
OFF
02745 - Bulb for Daytime Running Light; Left
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.18
Time: 17:25:14
Freeze Frame:
Term 15 On
Voltage: 11.50 V
ON
ON
ON
OFF
OFF
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 206
Mileage: 29688 km
Time Indication: 0
Date: 2015.10.19
Time: 17:04:02
Freeze Frame:
Term 15 On
Voltage: 11.95 V
ON
ON
ON
OFF
ON
03188 - Bulb for Side Marker Light; Front Left
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 226
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.18
Time: 17:25:20
Freeze Frame:
Term 15 On
Voltage: 13.45 V
ON
ON
ON
OFF
ON
03189 - Bulb for Side Marker Light; Front Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.18
Time: 17:25:20
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
ON
OFF
ON
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM053ZG9
Coding: 00005033
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 75CF03F6D44D8A9652-8020
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y1400014H6Y0Y
Coding: 303046
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME3F357842ZZZ/
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME62796B43ZZZ%
Crash sensor for side airbag; rear; driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME0B7A462CZZZ+
Crash sensor for side airbag; rear; passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME0570442CZZZO
Crash sensor for front airbag; driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME2E1F162CZZZ4
Crash sensor for front airbag; front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME450D7F2BZZZ9
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 BM HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140221300915
Coding: 0892140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 79D70FC6F855EEF636-802C
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-YVJ H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 561 920 970 F HW: 561 920 970 F
Component: KOMBI H04 0811
Serial number: 00000000000000
Coding: 231C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 04051403000280
Coding: 461000
VCID: 7BDB15CEFA69DCE624-802E
Address 1C: Position Sensing
Cannot be reached
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0811
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AF5208A8DF3556ECF-803E
Address 2E: Media Player 3
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0008241634
Coding: 0404F5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5B9B754E52A93CE644-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B
Component: J388__TSG_HL 006 5470
Serial number: 14102630140421162144
Coding: 800000
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 288 3501
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 3957CFC670D52EF676-806C
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 214
Mileage: 37387 km
Time Indication: 0
Date: 2016.01.25
Time: 08:59:33
Freeze Frame:
Voltage: 13.88 V
DU
Temperature: 15.0°C
RPM: 2957 /min
Speed: 29.0 km/h
Speed: 33.0 km/h
Count: 0
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 00000008
VCID: 6FC3319EBE11B04698-803A
Subsystem 1 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0008253967
Coding: 0404F4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5C99765257A73BDE4D-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B
Component: J389__TSG_HR 006 5470
Serial number: 14102631140429194703
Coding: 800000
1 Fault Found:
67589 - Turn Signal in Exterior Mirror
B11FD 01 [008] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 29698 km
Date: 2015.10.19
Time: 18:03:58
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H07 0009
Revision: -----12S Serial number: VWZ4Z7P3567016
Coding: 0100044004000B
VCID: 2B7BE58E4A898C66F4-807E
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 148
Mileage: 11719 km
Time Indication: 0
Date: 2015.05.04
Time: 10:43:45
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 225
Mileage: 37225 km
Time Indication: 0
Date: 2016.01.20
Time: 10:43:43
Address 75: Telematics (J949) Labels: None
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140517
Coding: 02140102C2161A107F1606C00000
ASAM Dataset: EV_OCULow 001010
ROD: EV_OCULow.rod
VCID: 538B9D6E3A79F4A69C-8006
3 Faults Found:
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 37225 km
Date: 2016.01.20
Time: 16:17:00
9457664 - Function limitation due to excessive temperature
B1050 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 97
2103041 - Control Module
B1788 F0 [009] - Start Prohibition Deactivated
Freeze Frame:
Fault Priority: 8
Fault Frequency: 1
Reset counter: 190
Mileage: 38116 km
Date: 2016.02.01
Time: 16:44:25
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665976407
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 2E7DEC9A719BF94ED3-807A
End-------------------------(Elapsed Time: 02:22)--------------------------
1 - 1 of 1 Posts
