Re: vag-com, nm to ft/lb' (platinum)
quote:[HR][/HR]so basically a block 120 is just a ruff estimate of what im getting. i should go get dyno'ed for the correct results.
no one has a conversion factor for the correct readings.
thanks again.
platinum[HR][/HR]
Block 120 shows actual wheel tq and hp including loss due to alternator, a/c, etc. but it also derives its readings from the MAF readings, MAP readings, etc, as well, so they are not 100% accurate.
.7376 is a good conversion factor from Nm to ft/lbs, and the to go to Hp the formula is (tq*rpm)/5252 just as others have said. everyone has given you the correct conversion factors, it's just the Block 120 is not 100% accurate but it is darn close. my readings would indicate that my car is making the power to the wheels
