1 - 5 of 5 Posts
Hello,
Anyone know how I can "Login" to the Engine Control unit using Ross-Tech? I want to read the adaption blocks on my V10 TDI but they are locked out unless you know the "Login" code which I obviously don't have. I think that the service manual has this information in the event anyone has the factory service manual to look this up.
Thanks for any help
Modified by V10 at 2:35 PM 2-20-2005
Modified by V10 at 2:47 PM 2-20-2005
Re: (ace_vwtech)
Often the EGR systems clog up with sludge and varnish over time. You can read what the air ratio or blend ratio of fresh air to recirculated exhaust is from the Engine control unit channels using Vag-Com. If the specs are off you can adjust the EGR cycle. In order to read what the current cycle is you must access the adaptation channel from the engine control unit and need the correct "Login" code to do such.
Modified by V10 at 11:34 AM 2-21-2005
1 - 5 of 5 Posts
