Yeah. I get really into this sorta thing. :laugh:LIJetta: Wow, it is rare to find someone with so-much passion over a database about adaptation channels - I'm impressed (and I don't get impressed easily)!
Are there really duplicates in my spreadsheet? I used the "exact" function in MS Access to distinguish between channel descriptors, so records that might look like duplicates could have subtle differences (like an extra space, or a different number in the parentheses), I was going to go through those descriptors that were similar and to make a judgement about keeping them (or, not), but it all got too hard, so I left them in. I'm more than happy for someone else to do it if they have the time and the commitment.
Funny. I thought I asked a few people about just doing this but no one seemed to give a straight answer or it was just not done properly by them.The following changes removed the "wink" feature. Those that don't like the feature this is for you.
Description Module Channel Original New Disable Turn Signal Wink
09 - Central Electronics
(8)-Leuchte3SL VRB21-Lichtfunktion C 3
Blinken rechts aktiv (beide Phasen)
Not Active (8)-Leuchte5 TFL RB32-Lichtfunktion C 5
Not Active (8)-Leuchte2SL VLB10-Lichtfunktion C 2
Blinken links aktiv (beide Phasen)
Not Active (8)-Leuchte4TFL LB4-Lichtfunktion C 4
Not Active
Jeremy: It must be the fact that we don't speak the same kind of English down here in the very, very deep south... Haha!!- When you say that the "wink" is removed, what do you mean?The following changes removed the "wink" feature. Those that don't like the feature this is for you.
gtimaneg: We got another way of doing it in the Southern Hemisphere!!!Just got mine, and found this
anyone try this?
Your car does this. It is when the the car has the DRLs on, you flick the turn signal on (either direction) and on that side only, the DRL will turn off until the turn signal is turned off. Then the DRL will turn back on.Jeremy: It must be the fact that we don't speak the same kind of English down here in the very, very deep south... Haha!!- When you say that the "wink" is removed, what do you mean?
Awesome, it worked! :beer:The following changes removed the "wink" feature. Those that don't like the feature this is for you.
Not Active
Awesome work man. I didn't like the feature before but I don't mind it now. Bummed no one still hasn't found out how to run fog and led's in the auto position without the headlights turning on yet.The following changes removed the "wink" feature. Those that don't like the feature this is for you.
Not Active
I agree, I always run by fogs and DRLs and turn it to AUTO when leaving the car. Then I forget so Im driving around all day with my low beamsAwesome work man. I didn't like the feature before but I don't mind it now. Bummed no one still hasn't found out how to run fog and led's in the auto position without the headlights turning on yet.
Checked for faults and there haven't been any. I did some hard cornering yesterday and in a way it felt like it handled better BUT that feeling could totally be in my head. Either way, I'll leave it like this since it hasn't had any bad effects. I guess they just renamed the channel to "No Display" so people don't mess with it... If anyone from RT could chime in on this it would be cool just so we know for sure.Patrick: Thanks for the Adpmap file. You're certainly correct about the "no display" channel (I've not seen this before). I've also had a look at your coding string. Nothing jumps out at me that suggests a way-forward. In fact, quite the opposite- the coding value in your control module has confirmed that my two candidate "enabling bytes" are incorrect! Have you noticed any changed behavior in your car since the setting was modified to strong and have you done an auto-scan since the change to see if there are any errors?
Agreed on this.I agree, I always run by fogs and DRLs and turn it to AUTO when leaving the car. Then I forget so Im driving around all day with my low beams![]()
Patrick: if there is no discernible difference with the new setting, then why have the new setting? No offence to Ross tech, but I gave this topic a fair airing on their forum, without much joy - with the plethora of new VW models being released onto the market across the world daily, we can't expect the talented RT folk to know everything! But you could try re-opening the topic on the RT forum again - doesn't cost anything to try!Checked for faults and there haven't been any. I did some hard cornering yesterday and in a way it felt like it handled better BUT that feeling could totally be in my head. Either way, I'll leave it like this since it hasn't had any bad effects. I guess they just renamed the channel to "No Display" so people don't mess with it... If anyone from RT could chime in on this it would be cool just so we know for sure.
Jeremy: Bummer-Thanks for the heads-up!!For anyone that wants to have the front ambers on all the time just beware that this can happen.... This is from having them set to 100% and probably 3 hrs of driving.
Thanks!Jeremy: Bummer-Thanks for the heads-up!!
I guess that stuff like this is a risk for those that I call, "early adopters" (i.e. pioneering folk that are prepared to experiment). Probably little solace to you, but the rest of us benefit from these types of events.
I assume that the LED lamp (the one at the top) is still working. Can't clearly see from the pic. It appears to be on a rakish angle to the socket- but it doesn't look that bad...
Can you post the coding for that tweak? I currently have my DRLs turned off, but I would keep them active as the fog lights. Do they come on at reduced intensity?PS: for those that have a predelection for fog lights- are you aware that there is a tweak to use fog lights as the Daytime Running Lights (instead of the normal DRLs)
Cajun: I've not tried the tweak, so I can't vouch that it works, but the tweak comes from the Stemie.de site. Anyway, with the aid of Google translate and the "09 Adpmap_Golf compare" file that I posted previously, the tweak instructions go something like this:Can you post the coding for that tweak? I currently have my DRLs turned off, but I would keep them active as the fog lights. Do they come on at reduced intensity?
Did this yesterday and this morning when I started the car I got warning messages about "check DRL function" and a yellow warning light all the way to work. Any ideas?The following changes removed the "wink" feature. Those that don't like the feature this is for you.
Not Active
