1,301 - 1,320 of 1,333 Posts
I have an 2011/12 Golf R ROW.
Can someone please help guide me on how to fix these headlights errors...... Thanks.
Tuesday,21,April,2015,17:44:46:33490
VCDS Version: Release 12.12.3
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Control Module Part Number: 5M0 907 357 C HW: 5M0 907 357 C
Component and/or Version: AFS-Steuergeraet 0148
Software Coding: 1477724
Work Shop Code: WSC 01357 011 00200
Additional Info: 7L6941329B AFS-Lst.-Modul l 0005 ID-R fehlt AFS-Lst.-Modul r ....
VCID: 34616A8B57B9BDBE4F5-8061
Fault Codes have been Erased
5 Faults Found:
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 73126 km
Time Indication: 0
Date: 2042.14.11
Time: 17:44:20
Freeze Frame:
Voltage: 11.79 V
Speed: 0.0 km/h
ABS 1
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
coding for instrument cluster
Dear forum members,
Recently i bought an MY2011 MK6 Gti in the Netherlands,
I have a strange problem with my instrument cluster needles ( the long ones)
They are lit very dim compared to the short needles. I could not found anything related to this in the coding. I am thinking i has to do with the byte 18 coding in cecm?
here is my full scan of the car :
Monday,17,August,2015,14:04:24:32364
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 15.7.0.1 (x64)
Data version: 20150729
www.Ross-Tech.com
Dealer/Shop Name: tolunay gul
VIN: WVWGD7AJ9BW License Plate:
Chassis Type: AJ (7N0)
Scan: 01 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55 56
62 72 77
VIN: WVWGD7AJ9BW Mileage: 19990km-12421miles
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AQ HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0040
Revision: E3H25--- Serial number:
Coding: 0403010818070160
Shop #: WSC 00191 264 15243
VCID: 75CF173E1CBF5A9675-8021
No fault code found.
Readiness: 0010 0100
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C492A0003881406EB92210041B70800
Shop #: WSC 01357 011 00200
VCID: 78D11E0ACBAD27FE6E-802D
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial number: 0144798723
Coding: 030C1C
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP.rod
VCID: 334BE9269A4B04A69B-8067
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AC HW: 7N0 907 426 AC
Component: AC Manuell H18 0303
Revision: 00013001
Coding: 0000004002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 75CF173ED4BF5A9675-8021
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AF
Coding: 6F180A3F80272AC49048028171008B84466D0011655D8DF0E4882020A040
Shop #: WSC 12345 123 61029
VCID: 3A55C402B521F5EE58-806F
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 11031 26 0512
Coding: 009F95
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R02280F
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 3957DB0EB827FEF651-806D
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0005LPJ600
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME4532205DZZZR
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME402E255DZZZ$
Crash sensor for side airbag; rear; driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME7419077CZZZ
Crash sensor for side airbag; rear; passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME5658097BZZZ0
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME6C617526ZZZL
Crash sensor for front airbag; front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME1C617526ZZZH
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110329301698
Coding: 1002140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DDF0F1EEC8F02D63D-8029
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 971 C HW: 5K6 920 971 C
Component: KOMBI H20 0420
Serial number: 00000000000000
Coding: 170F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 354FD73E943F1A96B5-8061
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 020411F2002131
Coding: 350002
VCID: 3041E62A635D3FBEE6-8065
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 19996 km
Time Indication: 0
Date: 2015.08.17
Time: 13:59:34
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0420
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AF534428D01856EE8-803F
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000077897004
Coding: 4100000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E7DF8527169294EF4-807B
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669690499
Coding: 020000
VCID: 28710E4A5B8D777E3E-807D
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 B
Component: RNS-MID H11 3890
Revision: AB001001 Serial number: VWZ6Z7K3380251
Coding: 00050400040000920005
VCID: 2F43E5567E632046FF-807B
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 3147E32EA85736B6E9-8065
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 3449EA3A5745039E82-8061
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109117144
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 67F34D769E13B806F7-8033
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 3245EC22AD510DAE90-8067
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1446940
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012557
VCID: 354FD73E5C3F1A96B5-8061
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 364DD0324139118EBC-8063
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669591490
Coding: 0800000000010100
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 62E55C627531DD2E20-8037
End-------------------------(Elapsed Time: 02:13)--------------------------
I even took the instrument cluster apart and connected it to the car, the Led's for the long needle were on but very dimmed.
i have pictures of the cluster
closeup of the cluster
overvieuw from the back
Is this an coding issue or i there someting broken in the instrument panel ?
Hello, Has anyone been able to get the mirror auto fold activated via VCD's on a jetta mk6 2014 TDI ?
I really want the auto folding feature but have to manually open and close the mirrors everytime i get in and out of the car, I have a Vag cable 12.12.3 version currently but also have access to the original ross tech cable, Any help would be highly appreciated.
I know on the GTI it requires different mirror assemblies from the ones that come with the US models. Is that the case for the Jetta too?
From what I've read, I do believe this to be the case. It sounds like every model across the globe can do this with VCDS, except NA...
Someone in Australia said that you also need the memory seats? Why the he|| doesn't my Prem/Nav TDI have memory seats?!?!
***EDIT***
Sorry, this is for the mirrors down in reverse feature. I'm not sure if it applies to folding mirrors.
Sent from my SM-N910V using Tapatalk
So I asked about this in the A3 forum but through some searching have now found this thread; hopefully you guys can help.
I recently swapped the European headlights onto my 2013 A3 -- these ones:
Everything lights up as it should, but of course, my diagnostics are now telling my that my (now non-existent) side markers are out. I found some info elsewhere that seemed to indicate one fix would be to turn off the cold diagnostics, but so I am wondering:
1. is that the best way to do it or is there some coding to turn off the side markers entirely (that I assume must exist for all the RoW cars)
2. if turning off the cold diagnostics is the only/best way to deal with this, is there a bit that is a specific side marker cold diagnostic?
I don't have the ability to do this myself so I may have to take it to the dealer to have it done and would like to hopefully give them as much info/instruction as I can. Thanks in advance for any help/pointers.
VCDS headlight coding questions on 2015 jetta
So i have a US Spec 2015 jetta SE "facelift" that came factory with halogen headlights. Well i recently just bought some OEM European Spec Bi-Xenon headlights for my jetta.
Do i just need coding? i found some people have needed a highline CECM? what is a highline CECM?
The Euro Spec lights are the GLI Bi-xenon with LED Day Running Lights!
So for starters i just unplugged my stock headlights and plugged the Euros in just to see what i was working with.
Now with the car OFF but the lights ON the LED strip and bi-xenons are working as they should but once the car is ON and i turn the lights ON i get the light out error and the LED strip and bi-xenons flicker?
My coworker said maybe the flickering is the car trying to read the new lights(kinda like what his BMW does) but i don't think thats it.
Im hoping its just coding that needs to be done but i was trying to read up on it and some people were saying i need a highline CECM but the trick is finding out the right CECM to use it hard.
I haven't found much because my car is so new and its the "facelift model" I'm not sure where to start!
Any help would be greatly appreciated!
Thanks in advance everyone!
If you have:
then you have folding mirrors. To activate auto folding follow this DIY:
http://forums.vwvortex.com/showthre...?7175626-Passat-CC-auto-folding-side-mirrors-DIY-tutorial-(nice-coding-feature)
If you don't have foldin mirrors, you need to replace your mirrors.
To solve the flickering, Enter 09-CECM - Byte 19 - Change value of Bit 4-7 to 00-Tail Light Dimming (Life Extension) inactive.
Took the car to a shop with VCDS, no luck.
Tried the setting for "disable side markers" and it still gave a light out warning.
Tried turning off cold diagnostics and no such setting appeared in long coding -- there was no "bit2" in byte 2.
Anyone able to shed some light on what I am missing here? Am I the only person in the entire US running the european headlights on an A3?
cruise control retrofit
Hello
this is my scan
i have install 1k0953513A stalk with cruise control activated in 01 in long coding cruise control and in 16 cruise control stalk ,but i get error in instrument cluster beside cruise control icon .
Question do i need to do some wiring from control module to ecu if yes can anybody supply me with correct pinout.
Help will be nice
10-Park/Steer Assist -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 B HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 5863
Revision: -------- Serial number: 00000000000000
Coding: 00114016030400080000
ASAM Dataset: EV_ECM16TDI02103L906023B 001005
ROD: EV_ECM16TDI02103L906023B_VW36.rod
VCID: 2567DC54243F5C3072A
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0104
Revision: 00H35001
Coding: 0001281
VCID: 7BD3DA2C3A3B3AC074E
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_VW36.rod
VCID: 7DD7D434EC2F34F04AA
Part No SW: 1K0 937 086 C HW: 1K0 937 086 C
Component: BCM PQ35 M 103 0575
Revision: 00103 AG
Coding: 46180ABAE87730C000480081310081EC47710088517D810064 8069200000
VCID: 30493D0063FD099891C
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 01031 21 0512
Coding: 009F95
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSen 05 0605
Coding: 06304D
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 C HW: 1Z0 919 475 A
Component: PARKHILFE 8K H06 0006
Revision: -------- Serial number: 66540926203266
Coding: 100001
Shop #: WSC 12345 123 12345
VCID: 41AF68C4D85790106E2
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA4PPUU
Coding: 00003132
ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3B531A2CB2BBFAC034E
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Serial number: 3572MSME5D576250ZZZ-
Crash sensor for side airbag; passenger side:
Serial number: 3582MSME3D1A4351ZZZY
Crash sensor for side airbag; rear driver side:
Serial number: 3512QSME0A115045ZZZH
Crash sensor for side airbag; rear passenger side:
Serial number: 3522QSME0845511FZZZV
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000004
VCID: 832322CCC2CBC200BCE
Part No SW: 5K0 920 860 J HW: 5K0 920 860 J
Component: KOMBI H04 0308
Coding: 170900
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 3343320C9AEB3280ECE
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 260210F1002738
Coding: E9A07F06400602000002
VCID: 69FF906440A7B850962
Component: IMMO H04 0308
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAFD6F680DA133481F8
Part No SW: 1T0 035 680 L HW: 1T0 035 680 B
Component: RNS-MID H04 5218
Revision: AB001001 Serial number: VWZ6Z7J8015169
Coding: 00010400040000000000
ASAM Dataset: ------------------------- ------
VCID: 375B061C8693DEA0D06
Subsystem 1 - Part No: 1T0 919 859 C
Component: EU East V9 7894
Component: Tuer-SG 009 2113
Coding: 0000180
VCID: 314F3804A8F700909E2
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
Coding: 0000180
VCID: 324D3708ADF13B88E78
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 3441311057E535B8F54
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
VCID: 35470C145C9F2CB0C2A
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 B HW: 3C8 035 730 B
Component: Telefon 011 X701
Revision: -------- Serial number: 35909603046757
Coding: 020100010100010000000400
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_VW36.rod
VCID: 226DC7483511AB08178
solved
stalk have separate ground on pin 5 and 10 soldered together and solved
Hello
this is my scan
Help will be nice
Revision: 00H35001
Coding: 0001281
Revision: 00003001
Coding: 0000000002
Revision: 00103 AG
Coding: 009F95
Coding: 06304D
Coding: 100001
Coding: 00003132
Coding: 0000004
Coding: 170900
Coding: 000000
Coding: 0000180
Revision: 00H17000
Coding: 0000180
Coding: 0000144
Coding: 0000144
coding for dast lights
Did anyone ever figure this out so that the dash lights stay on?
Got mk6 golf 2.5L that blue tooth is weird. If phone is in car and Bluetooth is on it connects to car(normal) but if I want to listen to radio I push button and will stay there less than a minute and switch back to the Bluetooth input. Any suggestions
Window auto up/down disable (passenger side)?
2012 GTI Autobahn Manual
Windows and switches all stock
I like the window auto up/down on the driver side (via the door mounted switch).
But would like to disable that feature on the passenger side window.
I searched but did not find anything here or other sites.
Has anyone figured out how to do this?
