1281 - 1300 of 1304 Posts
21 Arteon SEL R-Line w/AWD - Urano Gray
anyone else w a ‘21 have issues with signals not rolling to 4?
I haven't tried it but it wouldn't surprise me if it doesn't work right. There are a few apps on there that don't seem to work. For example I bought the needle sweep app but apparently it doesn't work on the 21's. I'd ask @OBDeleven support about it and maybe get your credits back if they can't get it to work.
i used carista for the needle sweep. didn’t work with them too. i contacted cs and this is what they sent back:
Thank you for using Carista, and I am sorry to hear about the trouble.
The task of the Needle Sweep was to test the needles if they have had a technical difficulties. Once the digital cockpit came out and the dashboard no longer had any analogue needles, the needle sweep is no longer required. As such, most cars do not have the software to run it. Even though Carista can activate it, there is no software to run the customization itself. I am afraid that this is the reason why it's not working. Be aware that it's very likely that it wont work with any other app, but if you do try it out, let me know how it goes.
I'm not sure if Carista charges per mod like OBDeleven but that's probably the response OBDeleven would say. Then I would ask wth are you selling something that doesn't work? I'm pretty sure that's the definition of scamming.
with carista its 9.99 a month, 19.99 for 3 months and 49.99 for a year. you have unlimited access to whatever apps they have(will have) until your subscription ends so if you know some people who want to mod their cars you can go crazy for at least 30 days! you can’t do any long coding though
@ice4life With the R logo in the cluster, is yours on all the time?
I turned it on on mine, but, as soon as the LKA icon pops up on the bottom, the R is gone. It's only there when I startup and shut down the car.
Correct! It's not there all the time
if you move the driver assistance to either one of the dials or to the center mfd, then it is there all the time. That’s what I do. You could also turn lkas/acc off and it’ll show all the time.
What am I doing wrong? Have OBD11 Pro version, went thru apps and made some changes. Seem some took, but not others. Specifically the comfort turn signals. Says I have selected 4, but still only get 3 flashes.
I remember in the past in order to get that to work, I needed to reset the lights to factory defaults in the car light settings menu. But the 21 doesn’t have this option anymore so I’m not sure how you do that now
it is not supported on the newer 10” cockpit. Only works on the original 12” version for some reason.
Needle sweep only works on 2019’s, VW changed the digital cluster on the 2020’s, which no longer supports needle sweep even though the option shows up on all coding devices.
Go into control unit 09 - Central Electrics < Adaptations < Aussenlicht Blinker and see what your numerical value is for Komfortblinken Blinkzyklen. Change it if necessary to match what you want. I'm just glad my wife is German
Sent from my Google machine using the tappy talky app
!!PLEASE WATCH BEFORE USING VCDS SCAN TOOL!!
WARNING
Work at your own risk. This work is inherently dangerous and must only be carried out by a qualified mechanic. Some of these mods might not be for your car, depending on installed equipment and model VW.
Security Codes:
31347
20103
19249
S12345
Guide
Disable Soundaktor
Disable the Soundaktor unit (if installed), which creates a fake engine sound when driving.
Select Structure Borne Sound
Adaptations
Select ‘Channel of Structure Bore Sound’
Change Value from 100% to any desired value, or 0%
Enable 360 View on Headunit
Enables 360 view of your car in AreaView "If equipped with side and front cameras"
Select Control Unit 6C (Back-Up Cam)
Coding - 07 Long Coding Helper
Check Bit 5 (3D_Presentation,On)
Next, In the Area View display tap the 360 button in the lower right hand of the screen
Enable Traffic Information (TMC) on Headunit
This enables the ‘Traffic’ button to work on the headunit, and will use radio frequency data to display nearby traffic information. Once activated, in may take over an hour for the initial messages to appear.
Select Control Unit 5F (Information Electrical)
Adaptations
Change Fee Based Traffic Information (TMC) value to ‘1024’
Next, in the normal radio settings, enable ‘Traffic Programme (TP)’ and RDS
Enable Off Road Display
This enables an ‘Off Road Display’ on the headunit. Once enabled, it will appear under the ‘Car’ Menu, tap ‘Selections’ and tap Off-Road.
Security Access 31347 or 20103
Adaptions
Change – (81) Car_Function_Adaptations_Gen2-menu_display_compass to Active
Change – (83) Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high to Active
Change – (41) Car_Function_List_BAP_Gen2-compass_0x15 to Active
Restart the MIB Headunit (Hold the Power button for >10 Seconds)
Heated Seat Memory
Heated seats will resume last setting upon re-entering the vehicle.
Select Control Unit 08 – HVAC
Adaptation
Change “Retention of the seat heater level driver” to active
Change “Retention of the seat heater level passenger” to active
Starting Vibration Reduction
In wheel slip scenarios, where wheel hop is typically induced, this tweak will stop the intervention of the braking system, allowing you to continue spinning the wheels. Assist with launching the vehicle, and stops the car from ‘bogging down’.
Select Control Unit 03 – Brake
Adaptation
Set to Starting Vibration Reduction and Torque Limitation to ‘Deactivated’
Haldex All-Wheel-Drive Adjust Traction
Reports indicate that changing this setting to ‘Increased Traction’ improves the handling and makes the car feel like a permanent AWD system.
Select AWD Control Unit
Adaptation
Logic
Choose from ‘Standard, Increased Traction, Less Noise’
Drive Profile Display in Cluster
This tweak will show the driver profile name in the cluster when switching modes.
Select Control unit 19
Control unit long coding
Byte 08
Bit 4 Activate
ESP Option in Car Settings
Show the Electronic Stability Program setting within the car menu on the headunit.
Select Control unit 03
Byte 29
New Value 09
Oil Temperature Display in Cluster
Displays the engine oil temperature in the cluster.
Select Control unit 17
Byte 10
Bit 01 Activate
Fog Lights On with Indicator
Fog lights will turn on when indicating. Fog lights must be fitted.
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
(2)-Static AFS Light Vorschrift
Value = FMVSS 517 108
Increase Intensity of Rear Lights
Increase the brightness of the rear tail lights.
Security access
Access Code 31347
Adaptation
(6)-Leuchte28RFL LC11-dimmwert AB28
Value=100
(6)-Leuchte29RFL RA64-dimmwert AB29
Value=100
Disable Start / Stop (Voltage Method)
Disable engine Start / Stop functionality.
Adaptation
Start Stop Limit voltage
Value=12
LED Fog Light Warning Delete
If you change the fog light globe to LED, this tweak will remove the error message typically displayed.
Security access
Access code 31347
Adaptation
(1)LB45-Leuchte12NL Lasttyp-12
Value= 6-LED Lichtmodule
(6)Leuchte12NL LB45-Dimmwert AB 12
Value=127
XDS Differential Lock Adjustment
XDS is an electronic differential lock, and lets you grip the road when cornering fast. It improves responses to ensure an even safer drive. In moments of fast cornering XDS lightly brakes the inside wheel to prevent wheel spinning. The result is better traction and a reduction of any tendency to under steer. This tweak will vary the aggressiveness of XDS.
Select Control unit 03 (ABS)
Adaptation
Select: Expanded Electronic Differential Lock
Options: Weak – Normal – Hard
Brake Drying System
This function increases safety in heavy rain, by applying the brake pads to the brake discs at prescribed intervals, in order to wipe away the unwanted film of water. Most drivers won’t even feel the system operating.
Adaptation
Select: Disc Drying
Options: Weak-Normal-Hard
Auto Close Windows When Raining
When rain is detected on the rain sensor, the windows will automatically close.
Security access
Access code 31347
Adaptation
(15) Access Control 2-Regenschliessen_ein_aus
Value: Permanent
(16) Access Control 2-Regenschliessen_art
Value: Permanent
(28) Zugriffskontrolle 2-Menuesteuerung Regenschliessen
Value:Aktif
Control unit Long Coding
Subsystem: Rain / Light Sensor (RLS)
Byte 0
Bit 1-Bit 2 DeActivate
Activation of Optical Parking Sensor (OPS)
Enable a visual graphic on the headunit when parking the vehicle. Uses parking sensors to display obstacles.
Select Control unit 10 (Assistance Situation)
Security access
Access Code 71679
Byte 2
Bit 0 Activate
Alternating Indicator Lights (Pace Car Lights)
For vehicles with Euro LED tail lights, the inner an outer rear indicators will alternate when indicating, or with hazard lights.
Security access
Access Code 31347
Adaptation
(16)-Leuchte2SL VLB10-Lichtfunktion G 2
Select: Blinken Links Dunkelphase
(18)-Leuchte2SL VLB10-Dimmwert GH 2
Select: yeni değer 0
(19)-Leuchte2SL VLB10-Dimming Direction GH 2
Select: yeni değer minimize
(16)-Leuchte3SL VRB21-Lichtfunktion G 3
(18)-Leuchte3SL VRB21-Dimmwert GH 3
(19)-Leuchte3SL VRB21-Dimming Direction GH 3
Fan Speed Display on Auto Mode
Show the A/C fan speed when operating in auto mode.
Select Control unit 08 (Air condition A/C)
Byte 11
Bit 6 Activate
Adjust Door Led Light Intensity
For vehicles fitted with LED Door lights, this tweak will increase the brightness.
Security access
Access Code 31347
Adaptation
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16
Select: max 127
(6)-Leuchte17TFLR SRB3TFL R SR KC3-Dimmwert AB 17
Select: max 127
Avoid Dimming LED Lights when Indicating
LED running lights typically dim when indicating. This tweak will remove this behaviour.
Security access
Access Code 31347
Adaptation
(12)-Leuchte2SL VLB10-Lichtfunction E2
Select: not active
(12)-Leuchte3SL VRB21-Lichtfunction E3
Select: not active
Cornering Fog Light Activation
Left or right fog light will turn on when indicating. Fog lights must be fitted.
Security access
Access Code 31347
Adaptation
(5) Leuchte12NL LB45-Lichtfunktion B12 auswählen
Select: Abbiegelicht links
(5) Leuchte13NL RB5-Lichtfunktion B13 auswählen
Select: Abbiegelicht rechts
Adjusting Cornering Fog Light Sensitivity (Speed Threshold)
With the above tweak enabled, this will adjust the speed in which cornering fog lights will turn on. Fog lights must be fitted.
Security access
Security Code 31347
Adaptation
(3) Static cornering light lower speed threshold
New Value = 0
(4) Static cornering light upper speed threshold
New Value = 50
Mirror Down in Reverse
The passenger mirror will dip when in reverse gear.
Select Control unit 52 (Türelektr. Beifahr.)
Byte 04
Bit 2-Activate
Bit 3-Activate
Access Code 31347
Adaptation
(15) Access Control 2-Spiegelabsenkung bei Rueckwaertsfahrt
Value=Active
(20) Access Control 2-Menuesteuerung Spiegelabsenkung
Value=Active
Hill Hold Assist Duration
Adjust how long the brakes ‘hold’ the vehicle when taking off on a steep hill.
Select Control unit 03 (Brakes)
Adaptation
Select Berganfahrassistent
Adjust as you wish. (default: Normal)
Refuel Amount in Cluster
After refuelling, the amount in litres will be displayed in the cluster.
Select Control unit 17 (Dashboard)
Byte 10
Bit 4 Activate
Coming Home Lighting Duration
After stopping the engine, your headlights will remain on for the specified duration.
Security access
Access Code 31347
Adaptation
(3) Comfort illumination-Menueeinstellung Cominghome
Value (Default: 15 seconds – maximum: 60 seconds)
Coming Home / Leaving Home with Fog Lights
Adds fog lights to coming home / leaving home functions.
Security access
Access Code 31347
Adaptation
(4) Comfort lighting Coming Home Lights
Value :Nebellicht(Low Beam)
Lock Acknowledge with Horn
The horn will beep when locking the vehicle.
Security access
Access code 31347
Adaptation
(1) feedback signals-Acoustic feedback
Value=Yes
(2) Lock feedback signals-Acoustic feedback
Value=Yes
(8) feedback signals-Acoustic feedback global
Value=Aktive
(7) feedback signals-Acoustic feedback
Value=Active
(8) feedback signals-Acoustic feedback duration
Value=Short(kurz)
Deactivate Warning Tone for Parking System
Disables the sounder for the parking sensors.
Adaptation
Park Assist Activation Tone
Value = OFF
Parking Warning Speed Change
Sets the speed where the parking sensors will be disabled.
Adaptation
Shutdown parking aid
Value = 20km/h
Hide Optical Parking System Warning Line
Disables the ‘Please check surroundings’ message that appears on the headunit when parking.
Security access
Access code:71679
Control unit Coding
Byte 1
Bit 5 DeActivate
Closing Windows When Ignition Off
Allows you to operate all windows after the ignition has been switched off and doors opened.
Security access
Access Code 31347
Adaptation
(13) – Zugangskontrolle 2 released trailing FH cancel at Tueroeffnen
Value = Aktif
Cluster Display Carbon Background
Change the centre cluster background visuals to a carbon-fibre style.
Adaptation
Screen view
Value = Option 2
Seat Belt Warning Deactivation
Disables the audible seat belt warning.
Adaptation
Select:Disable channel belt warning
Value:Yes
Byte 0
Bit 2-4 Deactivate
De-Fogger Timer
Adjust the operating time of the rear window de-fogger
Security access
Access Code 31347
Adaptation
(3) Window Air condition A/C condition A/C rear window heating value
Enter desired value
Tap to Indicate – Number of Blinks
When tapping the indicator to turn, this tweak will change the number of times the indicator blinks.
Security access
Access Code 31347
Adaptation
Comfort Sinyal Sayısı (Cycles)
Value: 1-5 Value 3 (Standard – 3x blinking)
Traffic Sign Assist Activation (Car must be fitted with Camera)
Vehicle camera will read traffic signs and display the posted speed in the cluster.
Select Control unit 5F (Information Electrical)
Adaptation
Select channel (63) vehicle function list BAP traffic_sign_recognition_0x21
Değer=Active
Select channel (151) vehicle menu operation-menu_display_road_sign_identification
Değer=Active
Select channel (153) vehicle menu operation-menu_display_road_sign_identification_over_thresho ld_high
Değer=Active
Control unit A5 (front / advance camera)
Security access
Access Code 20103
Byte 1
Bit 0 Activate – “01 Traffic Sign Recognition (FTE) active”
Byte 5
Bit 2 Aktivate
Adaptation
Select : channel numbers indicate end of speed limit
Importance to actively invest Show Valid suffix
View Channel Valid suffix
Corresponding value adjust default: 00100111
Lane Assist Activation (Car must be fitted with Camera)
Vehicle camera will attempt to keep the vehicle within the current lane.
Bye 4
Bit 6 Activate
Bye 11
Bit 1 Activate
Select Control unit A5 (front / advance camera)
Bye 0
Bit 0 Activate
Security access
Access Code 20103
Adaptation
Channel – Seçim HCA_On_State
Put emphasis on menu
Channel – Seçim HCA_Warning_intensity
Channel – Seçim BAP_Personalisierung
Put emphasis on not activated
Select the time of engagement
Set adjustment via menu – emphasis on late
Select Personalization spurt holding an assistant to a terminal 15 – channel
Set value to last setting
Select Control unit 44 (power steering)
Bye 0
Bit 0 Aktif
Select Control unit 5F (Informationselektronik)
Adaptation
(49) function -Vehicle list BAP LDW_HCA_0x19
Activate
(21) vehicle menu operation-menu_display_Lane_Departure_Warning
Activate
(23) vehicle menu Bedienung_menu_display_Lane_Departure_Warning_over _threshold_high – channel
Activate
Lane Assist Adjustments (Car must be fitted with Camera)
Adjust the point in which the steering wheel will vibrate to indicate the vehicle is drifting out of the lane.
Steering Wheel Vibration
Select Control unit A5 (camera)
Security access
Enter unlock code 20103
Adaptation
Select channel intensity steering wheel vibration
Value adjust accordingly Default: medium options: early, middle, late
Drivers Reaction Adjustment (Car must be fitted with Camera)
Adjusts the sensitivity in which the car will alert the driver due to lack of steering input.
Security access
Adaptation
Select channel deactivation threshold driver activity
Lap Timer Activation
Enable the Lap Timer in the cluster.
Byte 1
Bit 3 Activate
Gauge Needle Sweep
When starting the vehicle, the cluster needles will ‘sweep’ their entire range.
Byte 1
Bit 0 Activate
Adjusting Microphone Sensitivity
Adjusts the microphone gain for handsfree usage.
Select Control unit 5F (infotainment)
Adaptation
Select Mikrofonempfindlichtkeit (Microphone Sensitivity)
Adjust value as you wish.
Sunroof Opening With Remote Control
Sunroof opens when holding down the unlock button on the key fob. Also closes when holding lock button.
Security access
Access Code 31347
Adaptation
(9) – Zugangskontrolle 2 – SAD Richtung Komfortöffnen auswählen
Value = Tilting
DRL Only in Auto Mode
Only DRLs operate when headlight switch is in ‘Auto’ mode.
Security access
Access Code 31347
Adaptation
(9) – Select daytime running lights only in switch position auto
Value = Aktif
DRL Control on Car Menu
Enables a setting on your headunit which allows you to completely disable the Daytime Running Lights.
Security access
Access Code 31347
Adaptation
(2) Daytime running light activation by BAP or Operating sequence possible
Value = Aktif
LED Number Plate / License Plate Error Delete
If you install LED Number Plate lights you will typically get an error on the dashboard. This code fixes it.
Security access
Access Code 31347
Adaptation
Select – Leuchte25KZL HA59 – Lasttyp 25
Change value to Allgemeine LED
Select Leuchte25KZL HA59 – Dimmwert AB 25
Change value to 127 (Default is 100)
Full Rear Brake Lights (x5 Lights)
Enables your boot lights to also act as brake lights.
Module 09 (Central Electrics)
Security Access Code = 31347
Adaptation
Search for and select: Leuchte27 NSL RC6
Select: Lichtfunktion C27
Set to brake light = Bremslicht (default is not active)
Go back and search for and select: Leuchte27 NSL RC6
Go to: Dimming CD27
Set to 100 (default is 0)
Auto lock when exit
Adaptation
Control unit: B7 Access Startsystem Interface
Values:
passive_exit_door_slam_lock:
Old value: Not activated
New value: activated
Mileage: 23128 km
Date: 2019-04-24 22:05
Long coding
Values:
easy_close:
Mileage: 23128 km
Date: 2019-04-24 22:04
So is there any way to activate rear dynamic turn signals on a US Arteon Sel premium R line 2021??
I've been trying to find a way to configure lane assist to either remember the last setting or to default as "off" with the ability to enable. By default the 2021 VW Arteon (MIB3) has a default setting for "on (setting via menu)". I couldn't find anything from Arteon related forums but did find some information in both a Tiguan and ID.4 forum.
The suggestion was to go to "Module A5-front sensor for driver assistant systems". Under "Adaptions" there is a parameter "switch-on condition lane depart. warn". Security code 20103 works and your hood needs to be popped to make changes.
There are four values possible:
ON
OFF
ON (setting via menu)
OFF (setting via menu)
These are my results:
"On" - lane assist is on with no ability to turn it off
"Off" - lane assist is off with no ability to turn it on
"On (setting via menu)" - default is lane assist on but you can disable via menu, however, it will be on with next engine start regardless
"Off (setting via menu)" - the default is the SAME as "On (setting via menu)" , and it will be on with next engine start regardless of if you turned it off.
So, you can permanently disable, enable, or use factory setting lane assist but you cannot create a default to off with the ability to turn on with the Arteon with this method. Also, never found any way to just have the Arteon remember the last set value. Does anybody have an answer or know of a discussion about this that has an answer? I use Ross-Tech VCDS cable.
Thanks for any information.
ON
OFF
Okay, so I had some time and played around a bit and I believe I figured it out! Kinda. I determined a way to have the Arteon remember the last Lane Assist setting with the ability to turn on or off as you choose since there didn't seem to be a way to have the car default to off with the option to turn on.
Remember these are instruction for those using Ross-Tech VCDS cable. Make changes at your own risk!
So if you want to have Lane Keep Assist remember your last setting but allow you to turn it on or off via menu you need to use the long coder. You shouldn't have to touch adaptions in A5
Font Computer Display device Personal computer Electronic device
Enter security code 20103 and select Coding-07
To enable the car to remember last setting for Lane Assist (off if last off or on if last on) modify Byte 9 Bit 0-1 and select option 3 which will show Last_setting
Font Electronic instrument Technology Electronic device Audio equipment
You can save it here or you can go to Byte 8 Bit 5-7 and also enable Adaptive Lane Tracking as an additional menu option (I believe this just toggles between early and late lane assist intervention)
Plant Rectangle Font Line Parallel
Then save and Do It!
This Byte 8 change will show as a new menu item you see below and I have verified that the car will remember you last setting (like pre 2021 Arteon?) with the Byte 9 change. No errors or issues for me so far.
Radio Audio equipment Font Vehicle Satellite radio
