I needed this tonight, very helpful. :-DThis will not cover the situation when the doors are locked or not, but I have a rubber duckie held on with automotive-grade blu-tac where the hatch edge meets the bumper. I listen for the squeek it makes as it is squashed.
Evidently the "Facelift" R is not programed the same and I'm a dummy when it comes to this stuff so I'm not much help other than to tell you that my 2017 beeps when I close the hatch and the doors are already locked. Hopefully someone with more knowledge than I will chime in to help.I needed this tonight, very helpful. :-D
My 2019 does it as well.Evidently the "Facelift" R is not programed the same and I'm a dummy when it comes to this stuff so I'm not much help other than to tell you that my 2017 beeps when I close the hatch and the doors are already locked. Hopefully someone with more knowledge than I will chime in to help.
Hi, no.Hi all, my car is golf mk7 1.4 tsi and recently retrofit RCD 330 280B, all goes well except in the driving mode, no custom items can be changed in individual mode, any VCDS tweak can solve it?
On the initial screen, showing the default car, tap on Info and you should see a white 'pencil' appear at bottom right of the picture. Tap on this and choose "Change". You can then browse for a suitable picture. You may need to change the size and aspect ratio to get something suitable.Hi guys. I would like to know how to change "car photo" on the Car Menu of Display. Mine is Golf R MK7 and there is a simple Golf on Display. Thank you for helping
ZERO815 could you please send me an im, i'm having trouble finding the button. ThanksOkay try the following:
Leuchte23/Lichtfunktion B23/Parklicht links (beidseitiges Parklicht aktiviert li&re)
Leuchte24/Lichtfunktion B24/Parklicht rechts
If you want to add the inner tails as Parking lights as well:
Leuchte17/Lichtfunktion B17/Parklicht links (beidseitiges Parklicht aktiviert li&re)
Leuchte16/Lichtfunktion B16/Parklicht rechts
