I was just wondering if anyone knows a good source to purchase Velocity stacks for custom manifolds/ITB/carb setups?
I came accross http://www.velocity-of-sound.com, and they have a pretty good selection, but are a little out of my price range (I am trying to make mine on a pretty tight budget
A while back someone had made a set using thin walled aluminum pipe, and pressed a makeshift die (IIRC a chair leg
), flaring the top edge of the pipe creating a budget velocity stack.
I was thinking of using 1.5" Schedule 40 tubing, and attempting the same thing, but need advice on the best way to flare the tube using basic shop tools.
Is it best to attempt it cold, should the tubing be annealed first, is it possible to "stretch" aluminum into the desired shape?
TIA!
Graham.
TIA!
Graham.
