Re: (pturner67)
OK, I have the same problem and took the car in about 3 weeks ago. People are correct for the most part. The sound in coming from an evap line that is part of the emissions control system. What I was told: the flap will open and close (making that noise) in order to vent gas vapor in the line. This only does this at idle, when you open the throttle the flap has to close. Also, that in-line with the flap valve is a charcoal trap that captures spilled gas that may have gotten trapped in the line, than needs to be vented. The technician told me this is most common if you overfill (top off) you gas tank. He said all VW/Audi’s do this. In most of the models the valve at the rear near the gas tank, but in the A3, it is located under the firewall, and that’s why you hear it more.
I asked how often it would need to vent, and he said there is no way to tell. So my question was “So potentially it could do this all the time?”, his response was “yes”. I told the service manager that I did not think I could live with the noise if it did it all the time. So he told me if it does not stop, he would replace the valve and trap.
The technician did hook me up and look at fault codes. He also ran a self-diagnostic. Everything in the fuel and emission system showed up fine, yet the noise is still there.
I was worried because I installed the K&N filter, and thought that it might be causing some sort of valve problem. But now I know its not related to the intake
