According to the manual, the system will not play video files of any format, only DVDs. I'm sure there's a way around this some VCDS coding but straight from the factory, you've got to pop in an actual disc!
Hi, Is this possible for a 2015 A3 1.8t? These have the smaller screens compared to the S3. Also have a SD Card slot. but cant seem to figure out what video format it will play on.In my 2015 I am able to play videos via the sad card. I used handbrake to convert the videos.
You can used the standard iPhone play out and I changed the audio output to MP3. Once the video is playing you can select settings and change the video aspect.
I can look at the full spec frames per second if needed.
