Okay, there is an overwhelming amount of information on the "bucking bronco" syndrome, so I thought I would start a poll.
Let me say this. I do not want to spend $1000 in parts to figure out my problem, this is why I am doing a poll - attack the problem with statistics. Only people who have had this problem should participate in the poll.
update: Brand new bosch maf=still bucking.
The car:
93 Corrado VR6 Turbo. OBD2with C2 chip . 10psi.
original coilpack
original fuel filter and pump
original sensors
new plugs
Neuspeed wires < 2 years old
Symptoms: the car bucks violently with about 20% throttle - and I do mean engine mount breaking violent, there is an O2 sensor code, but whent he codes are cleared, the bucking causes no CELand no other codes. The wideband reads lean when the symptoms occur (this could mean not enough fuel, or missfires)
Scenario: Two days ago, I swapped my coilpack with a used one I had laying around to see if it would cure a slight hesitation problem. It didnt cure anything, nothing changed at all. One day later, the bucking started -so I changed the coilpack back to the original. The bucking still persists.
Please select what you think would cause CV shattering engine buck.
Modified by CannuckCorradoVR6T at 6:40 PM 11-12-2006
The car:
original coilpack
original sensors
new plugs
