1 - 14 of 14 Posts
Banned
cant seem to get a strait answer to how much psi this pulley is supposed to put out. and what kit does it come in?
thanks guys.
Banned
Re: Vortec Pulley...tried the search. (leebro61)
seems like u have all the answers to my questions http://****************.com/smile/emthup.gif
Banned
Re: Vortec Pulley...tried the search. (wr.millertime)
The 3.12" pulley that you have pictured, assuming that you are installing it on a Vortech (corrected: V9) unit for the VR6, will get you ~7 psi.....we have just supplied a Vortex member with a 3.14" and he told us that he was hitting 7psi. We also provided him with a 24# injectors EPROM, as he was running the....well.............24# injectors
C2
If you need that pulley, or any other diameter pulley, please let us know. We can also provide you with our new CAI, Dual idler pulley, brackets, etc.
http://forums.vwvortex.com/zerothread?id=1235449
http://forums.vwvortex.com/zerothread?id=1237870
Modified by C2Motorsports at 4:32 PM 2-14-2004
Re: Vortec Pulley...tried the search. (C2Motorsports)
chris, I respectfully disagree. The v9 blower that nater is running (I assume you were speaking of him) produces less boost when spun with a similarly sized pulley in comparison to a v1 or v2. The vf stage one pulley (3.25") makes 5-6 psi, while a barely smaller 3.125" pulley makes double that on a v2. I can only imagine the blower and its gearing is the difference. In comparison, I gained ~2psi by switching to a pulley that was just under .3" smaller than my original. The .125 change from the VF pulley to AMS/Eurotech pulley is insignificant in my eyes, meaning only gaining 1psi or so.
The 3.125" vortech pulley ( the ONLY 7 rib Vortech makes ) was sold with the AMS and eurotech kits and produces this much boost (10-11psi) when tight and revved to 69-7000.
http://forums.vwvortex.com/zerothread?id=807019
That was on a third gear dyno pull, I hope the video still works
If you dont believe me, ask scooter, twodubs, marty, sofa king, or anybody else who ran a v1 or v2 blower
Lee (da vortech guru
Modified by leebro61 at 1:17 PM 2-14-2004
Banned
Quote, originally posted by leebro61 »
Thanks Lee, I made the correction to my post, as I had put the wrong charger number down when I originally submitted it
You are earning that C2Motorsports jacket, now aren't you
Administrator
Quote, originally posted by C2Motorsports »
C2
And those injectors are done now...
. Jeff Atwood did a great job tuning those injectors!!!!
Thanks for the pulley as well!!! Has been running perfect! Lines up with my belts and all perfectly!!!!
And as you said, I'm seeing a consistant 1lb increase (hitting 7psi in the cold weather)...As many of you know this v9 3.25 pulley is a bit under 6psi when it's warm.
Later,
Banned
Discussion Starter · #11 ·
kinda on the same subject, when i bought this kit, it came with the wrong chip, so i need a new one. i have 310 injectors with this set up, vr6 coilpack.
i talked to leebro briefly about chips, was wondering what chips you guys use, and how much u paid. thanks. http://****************.com/smile/emthup.gif
Banned
Im SAE certified in vr6 vortech setups
And C2 certified......
great you 2 will come in handy when i start to put my kit on
1 - 14 of 14 Posts
