1 - 3 of 3 Posts
I have a 1990 g60 shell in good shape with a mint interior but no motor, I plan on installing a vr and was wondering what I need,
motor
trans
complete engine harness & computer ....
are the mouts the same as well as the front crossmember.
rad looks the same except with a single fan
clutch slave cyl. looks the same.
do I need a vr cluster f so do I also need the dash harness or does the g60 cluster and vr one interchangable.....
any help would be great... I am going to doa complete color change on the car but I would like to get all the parts together I need so that after we are done painting it I can slip the vr into it.
thanks again
Justin
I am an a$$ wrong forum please move .
Modified by turbo12v at 8:43 PM 2-12-2004
Re: ??? vr into a corrado g60 (turbo12v)
you are going to also need the SLC hood and sub-frame and the vr6 trans axles. im not sure if the 90 rad support will work. i think you need the 92 g60 one or one off a vr6. if you search you can find everything you need.
1 - 3 of 3 Posts
